Valve Spring ??
Old Jan 30, 2006 | 11:00 AM
byte_me's Avatar
byte_me
Default Valve Spring ??
Hello all -
I am in the process of buying a NEW set of 04 LS6 heads with stock valves, springs, retainers and locks...
My question is - if I want to put in a set of say Comp 918's do I need to get different retainers\locks etc... or can I reuse the NEW ones on the LS6 srpings and valves?
These heads have never been fired...
Also - the LS6 springs say they are rated to a .570 max lift, if I get a cam that is close to that (around .563) am I running a risk of spring issues being that I am close to the ceiling of the springs?
Thanks!
Old Jan 30, 2006 | 11:34 AM
lost's Avatar
lost
My understanding is that the 26918s are the same beehive design and same dimensions as the stock Ls1/6 spring, the only difference being open and closed seat pressures and coil bind dimensions, which determines useful lift.Where lift isn't critical ,but if more seat pressure is necessary, Manley makes a thicker[+.050} retainer.Keepers are the same, but if retainers are not titanium, titanium is recommended, they too are the same size.
Old Jan 30, 2006 | 11:37 AM
Jim Taylor's Avatar
Jim Taylor
I don't know the answer to the lift question, but you can definitely reuse the stock retainers and locks with the 918's. That's what I've done. I believe you'll need to switch to titanium retainers if you go with any stiffer spring; e.g., duals.
Old Jan 30, 2006 | 12:01 PM
vettenuts's Avatar
vettenuts
Don't re-use your stock retainers. Get the Comps. Fit of the retainer in the spring needs to be snug otherwise the spring will move relative to the retainer. I know a lot of people use their stock retainers, but it is asking for problems. Call Comp you will get the same answer.
Old Jan 31, 2006 | 08:28 PM
magredZ51's Avatar
magredZ51
Originally Posted by byte_me
Hello all -
Thanks!
Careful when selecting springs based on lift of cam. You need to
also consider the ramp rate of the cam. A more aggressive ramp
requires more spring pressure.
For example the popular TR224 is only .562 lift but has a lobe
somewhere between a XE and a XER, so LS6 springs are not
acceptable.
Old Jan 31, 2006 | 11:59 PM
Shane_S's Avatar
Shane_S
I'd get the Comp 921's with the their retainers and seats just to be safe.
Shane
To Valve Spring ??
