Cutting Off the oil filter??
Old Jan 30, 2006 | 02:56 PM
AU N EGL's Avatar
AU N EGL
Default Cutting Off the oil filter??
Ok guys
Working with a friend on his vette ( no not the AU N EGL ) and we cant get his oil filter off with the cup type filter changer. It on too dang tight and the cup just turns on the filter.
Cant seam to get the claw type oil filter change on, or a BF Channel Lock wretch.
any other thoughts, what else to try ????
I was thinking of taking the dremmel tool and cutting it off.
Old Jan 30, 2006 | 03:09 PM
bb609's Avatar
bb609
Never done it on a Corvette but I had to tear the filter off a 327 to get to the nut and then turn the nut with a cold chisel and hammer until I got it moving. I had taken to a tech school nearby for the last oil change. I change my own now, thanks.
Old Jan 30, 2006 | 03:12 PM
Face's Avatar
Face
You can try stabbing it with a screwdriver and turning.
Old Jan 30, 2006 | 03:15 PM
dpd's Avatar
dpd
try tightening it then try and take it off.
Old Jan 30, 2006 | 03:21 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I do that all the time..give it a try, works great
Old Jan 30, 2006 | 03:27 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Bingo,that will work. I have done this as well,but on other cars
Old Jan 30, 2006 | 03:35 PM
bb609's Avatar
bb609
And if it doesn't work, it's still a good beginning for the next step!
Old Jan 30, 2006 | 03:36 PM
chaase's Avatar
chaase
St. Jude Donor '12
Old Jan 30, 2006 | 03:37 PM
95jersey's Avatar
95jersey
works for me everytime! Get a nice long screwdriver and stab right through the aluminum.
Old Jan 30, 2006 | 03:40 PM
AU N EGL's Avatar
AU N EGL
43 min latter and 8 responses for STAB that thing with a screw driver. Thanks guys.
Old Jan 30, 2006 | 03:41 PM
Hall1836's Avatar
Hall1836
You can sometimes get them off with the cup type filter by wrapping a piece of sand paper around the filter and then putting the cup on.
Old Jan 30, 2006 | 04:15 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Have had to do this a few times on other peoples cars... I cannot understand why everyone puts the filter on Gorilla tight.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Jan 30, 2006 | 04:17 PM
AU N EGL's Avatar
AU N EGL
Sand paper worked.
Once I go it off I beat the chit out of it with a BFH. No not really but did cut it open an unfolded the filter paper.
Going to send his oil to the two oil testing companies I use.
My guess is they way he drove his car that 4500 miles between oil changes and the DIC oil indicator at 5% was NOT a good idea.
Thanks Guys
Old Jan 30, 2006 | 04:37 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
beat me to the punch
Old Jan 30, 2006 | 05:55 PM
VetteDrmr's Avatar
VetteDrmr
Originally Posted by AU N EGL
Sand paper worked.
That's a good idea; I'll put that one on the shop toolbox!
Nah, Mongo just put the last one on. It still amazes me how much a filter will tighten up.
Have a good one,
Mike
Old Jan 30, 2006 | 05:57 PM
rws.1's Avatar
rws.1
put a K&N oil filter on ... it has a 1" nut welded to the base. You will never have this problem again.
Old Jan 30, 2006 | 06:02 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Thanks Guys
it'll be fine...the computer takes into account a lot more than just time/mileage when it calculates oil life...I would bet he's no where near wearing out that oil
To Cutting Off the oil filter??
Old Jan 30, 2006 | 06:10 PM
Ttime's Avatar
Ttime
Be careful with this technique. I REALLY screwed up a few years ago. ack: I tore the aluminum off the base of the filter leaving me with a bigger problem. I had to use a small chisel and hammer to un-thread the base.
Old Jan 30, 2006 | 06:12 PM
Mikelly's Avatar
Mikelly
Sears has these neat little rubber strap wrenches that work wonderfully in these situations... I have them and recommend them highly!
Mike
Old Jan 30, 2006 | 06:56 PM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
Nobody really mentioned this particularly but the screwdriver has to go inside one side and out the other or else it usually rips the filter when it's on too tight. Obviously you have to be careful doing this - especially getting it to come out the other side without hitting anything else.
