Does harmonic balancer .. (quick help!)
Old Jan 31, 2006 | 12:30 PM
usnskeet21's Avatar
usnskeet21
Default Does harmonic balancer .. (quick help!)
Does the inside lip where the crank bolt goes need to be flush with the end of the crank... i am ALMOST there (1/8 -1/16 " MAYBE ) but i can get the crank on ANY further. I dont wanna be throwing belts when i get this back together... any help?
Old Jan 31, 2006 | 12:34 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
If I recall correctly when I did my cam swap, that bolt needs to be flushed with the balancer.
Hope things work out for you.
Micah
Old Jan 31, 2006 | 12:45 PM
vettenuts's Avatar
vettenuts
No, it does not come flush. There is a specification in the service manual on the distance, which I can retrieve later but am at work now. 1/8" is about right though.
Old Jan 31, 2006 | 01:21 PM
Jim Taylor's Avatar
Jim Taylor
It should not be flush. The service manual says:
Important: The nose of the crankshaft should be recessed 2.40-4.48 mm (0.094-0.176 in) into the balancer bore.
Old Jan 31, 2006 | 01:34 PM
The Wrench's Avatar
The Wrench
Yep. Mine was recessed 0.15". I measured very carefully when installing the ATI. I could actually feel when it bottomed, using a big break-over and cheater bar. It went from very hard to turn, to very-very-very hard to turn.
So, sounds like you're good.
Now put in a new bolt and do the 50 lb-ft, 140-degree thing.
when you're finished, put a sharpie mark on the bolt head and the balancer so they line up, then you can check them occasionally to be sure the balancer is not loosening. Good peace-of-mind.
DG
Old Jan 31, 2006 | 02:13 PM
usnskeet21's Avatar
usnskeet21
DG
Sweet, thanks for the tip. !!!
Old Jan 31, 2006 | 05:16 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
This is why I love this forum, people with the experience. I learned something very helpful.
Glad you got the right answer.
Micah
Old Jan 31, 2006 | 07:44 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I think it also says put some red loctite on the bolt.
Old Feb 1, 2006 | 07:27 AM
vettenuts's Avatar
vettenuts
Not the service manual. I personally think this is risky for later removal, a broken bolt in the crank is your worst nightmare.
Old Feb 1, 2006 | 06:56 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
I put an ARP bolt in.Boy I sure hope I don't have to take that thing out If that bolt breaks,thats a cheap bolt
Old Feb 1, 2006 | 07:41 PM
Rhode Warrior's Avatar
Rhode Warrior
Another check you could do: Before I removed the original pulley, I measured the distance from the edge of the crank pulley to the flat surface of the timing cover and it was exactly 1". When I installed the new UD pulley, it was the same.
To Does harmonic balancer .. (quick help!)
