Cleaning MAF
Old Jan 31, 2006 | 11:17 PM
JEEP/C5's Avatar
JEEP/C5
Default Cleaning MAF
What is the best way to clean the MAF? Should I use isopropyl alcohol and some Q-Tips and carefully clean? Remove and use some sort or cleaner spray on it? I dont have any issues with it just thought the next time i clean the K&N I would clean the MAF just so I know its clean and no oil or dirt on it.
Old Jan 31, 2006 | 11:40 PM
SynistrC5's Avatar
SynistrC5
For my own curiousity I once called Granatelli on this, and as scary as it sounds they said to use brake clean. I also contacted Best products way back when and they said to use electric parts cleaner. Needless to say I have not tried either one, but I am kinda scared to spray brake clean on anything other than new brake rotors and new flywheels. Any one else?
Old Feb 1, 2006 | 12:22 AM
vetteguy02's Avatar
vetteguy02
Isopropyl alcohol or an electronic cleaner (that will not leave residue) will work fine. I would spray a liberal amount of one of the above cleaners on the MAF wires and resistors and let dry. If you use Q-Tips the cotton fibers will stick to the areas you are intending to clean.
Old Feb 1, 2006 | 12:26 AM
rws.1's Avatar
rws.1
I have used brake cleaner, I have also used throttlebody and carb cleaner. No issues, no codes.
You want a pertroleum distillate. they evaporate and leave no residue.
Old Feb 1, 2006 | 12:35 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Brake Parts cleaner will not damage it. You can also use spray electrical contact cleaner.
BC
To Cleaning MAF
