Clutch advice
Old Feb 3, 2006 | 11:38 PM
WrEcKeD1101's Avatar
WrEcKeD1101
Default Clutch advice
Ok guys, I searched for aftermarket clutches here to see what some of the guys with higher HP applications are running, but the most I came up with was the LS7 clutch.
I be straight up...I am clutch dumb, but I know that mine is going to be replaced. I want to know what you guys with big HP numbers are running and how you like it. I will have a 402 with a magg on top until the KB comes out (if it ever does ). What do you suggest? The car will be mostly a street car and may see some autox (doubtfull ) and driven on nice days, so I can give up some stock feel for more performance.
Now....lay it on me!
Old Feb 4, 2006 | 01:07 AM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
do a search on the "textralia" clutch. hear nothing but good things. expensive, but supposed to be worth it. i went with spec 3 plus. having issues now, but not sure whats causing them.
LS7 clutch is just too new for me. i havent seen anyone post any numbers as to how much power the clutch will hold. there are a bunch of people running that setup now, but only time will tell how long that clutch will last with 500+rhwp
Old Feb 4, 2006 | 01:00 PM
WrEcKeD1101
Thanks for the info. Any others out there?
Old Feb 4, 2006 | 01:18 PM
mdhmi's Avatar
mdhmi
You're probably going to be pushing too much power to run an OEM LS6 or LS7 clutch.
I run 600 rwhp with the Exedy Twin without issue. The clutch is heavy but smooth.
Others seem to like the OZ700 aka Aussie/Textralia, RPS single, or Cartek clutches.
If you search long enough you'll find complaints about all of the aftermarket clutches.
Mark
Old Feb 4, 2006 | 01:43 PM
WrEcKeD1101
LOL...
I guess it's going to come down to pricing. Everyone wants the bang for the buck, but I want something that will hold everytime, no matter the cost.
Old Feb 4, 2006 | 03:08 PM
402Sam's Avatar
402Sam
I run the spec 5 clutch. Its good for 1200hp so it should hold up nicely. The only downfall to this clutch is the sqeeking I get from the solid disk. It sounds like a belt is squeeking but its the clutch. It only does it from a dead stop when I go to take off. Also this clutch is either on or off, kinda hard to slip sinice there isnt much clutch play. Its either goin to go or its push it in and its off.
Old Feb 4, 2006 | 03:29 PM
WKMCD's Avatar
WKMCD
I run the LS7 clutch with a Cartek adjustable master and it's great. I'm only at 470 RWHP though.
Old Feb 4, 2006 | 06:33 PM
binkysgarage's Avatar
binkysgarage
I think the jurys still out on the LS-7 clutch, we'll see what happens when the big HP cars run it. So far so good.
Old Feb 4, 2006 | 07:20 PM
C5 KIDD's Avatar
C5 KIDD
its not really HP #'s i would be concerned about. its HOW LONG will the clutch hold up with that kind of power?? big HP? the guy just above posted 470rwhp... likes it so far... but how long has he had it? how much does he abuse it? and how long will it last?!?
Old Feb 4, 2006 | 10:27 PM
WKMCD's Avatar
WKMCD
I've got about 2k on it now. No drag runs but I do drive it like I stole it!
Old Feb 5, 2006 | 05:22 PM
WrEcKeD1101
Thanks guys...I am still looking.
Old Feb 5, 2006 | 05:32 PM
Roadrace65's Avatar
Roadrace65
I would recommend having your new flywheel & pressure plate assy balance matched to the OEM unit. I picked up a-little vibration with an out of the box light weight unit.
Old Feb 5, 2006 | 07:56 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
slacker RWHP
When I have my heads installed, Im going to go with the LS7 clutch which Ill order this month. With my package, I should be at 410RWHP give or take 5 HP. The LS7 clutch will be perfect and very cost effect for me.
Guys with the 2006 Z06 are putting down an easy 450 RWHP. That clutch will be plenty for my application.
Old Feb 5, 2006 | 10:01 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I have the RPS clutch/flywheel in my car now for 2200 miles and I have well over 700 rwhp and it is holding up fine so far and it has had no slicks on the car but quite a few boosted shifts at 6k
Old Feb 6, 2006 | 12:31 AM
binkysgarage
I agree with you my LS-7 clutch was out 25 grams.
To Clutch advice
