Is This Cam Too Big
What heads? What valve sizes? Have the heads been milled? What's the lobe profile like?
No matter what, PtV clearance should be checked upon installation, even w/stock heads....a cam of this spec is way too close for anyone to give you a definite yes or no answer.
Anyway, my tuner (rwj383 on here) actually looked inside the cylinder during the cam install, and found there to be ample room between the piston and valve. He was a little concerned at first, and was planning on making cutouts in the cyl head, but it turns out he didn't have to.
However, those specs are a good size higher than mine. You oughtta PM directly some tuners on here, Robert being one of them, to make sure. Even if it was too close, it seems you could cut piston reliefs. Its just extra labor involved.
Please keep us posted.....
greg
If you want a guess, I would say yes, you will. I believe that cam is larger than a G5X3 on a 114lsa, and I've read here that is about the largest cam you can go with on stock heads.
BTW. as also stated above you can cut them fairly easily. You just have to take the heads off and use a cutting tool. Either make your own from an old valve or you can purchase the Isky cutters.
I did it on mine, see my sig. I cut .065"-.070" and ended up with .135"-.140" clearance. I was too close without cutting, due to the head gaskets, milling, and ICL.
