Massachusettes Inspection
Old Feb 8, 2006 | 01:03 AM
jackdaniels's Avatar
jackdaniels
Default Massachusettes Inspection
If I were to do all the possible bolt ons to an 03 coupe and have a custom Predator tune made, would I be able to load the stock tune back into the ECM before inspection and still pass? Here in Mass they hook their computer right up to the OBDII and if there is anything different then stock it will not pass.
Also, is a Predator a good enough tuner (with a custom dyno tune loaded onto it) to use with the installation of heads/cam, or a blower? And if it is would I still be able to pass the OBDII inspection?
Old Feb 8, 2006 | 06:37 AM
vettenuts's Avatar
vettenuts
Not sure where you are in Mass, but I wouldn't bother with the Predator myself. There is a tuner in Seekonk (goes by Slowhawk) who can do a custom tune and you will pass inspection as well. The OBD II scan is looking for "system ready" messages as well as errors, so as long as you are clean there shouldn't be a problem. From what he has told me, he has done a lot of cars with Predator tunes and found that they have cost power.
Old Feb 8, 2006 | 07:20 AM
SpeedyD's Avatar
SpeedyD
I'm right down here in CT and I believe they do the same test. I don't think they are looking to see if it's modifies, I thin they want to see if it's too modified. As long as you pass the limits that they have set you should be fine. I'm sure there are people in Mass that will chime in on this. You're probably worryin about nothing!! Have a good one!! Dan
Old Feb 8, 2006 | 09:52 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
When you put it back to the stock tune the computer will not be "ready" for the OBD test. Remove the tune at least 2 weeks before you go. Also do not clear any codes in that 2 week time, it will also show not ready and you will fail. It has happen to a few buddies of mine and I followed above and have had no problem
A lot of stations only look for the check engine light, and if they do not see one they just pass the car.
2006 = emissions/safty for odd year cars and just safty for even year cars. If I recall.
Good luck
Old Feb 8, 2006 | 11:38 PM
jackdaniels
Do you have a car that he has tuned and passed inspection in Mass? I would definatly be interested in doing something like that if it works.
Old Feb 9, 2006 | 06:29 AM
vettenuts's Avatar
vettenuts
I am in Rhody. He does a lot of cars that go through inspection, I would give him a call and speak to him directly. He is located at DEZ Racing, across from Seekonk Speedway. His name is Don. I really don't think it will be an issue, especially since big cam/heads cars are getting through but you should really speak with him. He lives in Mass and his car is by no means stock.
Old Feb 9, 2006 | 01:19 PM
JSTAN's Avatar
JSTAN
I have one. Passed inspection w/no problems..See sig for mods.
Old Feb 9, 2006 | 03:50 PM
01vetter's Avatar
01vetter
When did you pass? I believe that this year is the first for ODB II. Last year was just a safety check.
Old Feb 9, 2006 | 04:19 PM
95jersey's Avatar
95jersey
All they check for is emission codes...that's it! They can't see if you have a custom tune. That is simply ridiculous, without a labtop it's impossible. Do you actually think they go in and look at air/fuel ratio, rev limiter, sensor diagnostics? They look for a history of trouble/emission codes. They can't/don't look at anything else. They wouldn't even know what they are looking at? You would need LS1 edit to see that kind of stuff, so they would need a sofware edit for every kind of car made...NO.
The only reason they don't just look at your check engine light is because some people may disconect the bulb or pull the fuse associate with it. Also, they want to see the history of trouble codes. Some codes may go away, but will leave a history
Old Feb 9, 2006 | 05:37 PM
screw991le's Avatar
screw991le
But, when to access the computer for a tune/edit/code clear, the computer is NOT ready for the test.
Old Feb 9, 2006 | 05:50 PM
95jersey's Avatar
95jersey
Yes, in a way. You can't tune a car, clear the codes then run it through inspection minutes after. Once you tune the car (which it's sounds he's already done), you simply need to put miles on the car without any emission codes. DON'T CLEAR CODES BEFORE YOU GO TO THE INSPECTION!
If you have codes, you have a legitimate problem that needs to be fixed.
Theoretically, with the right tune, you could run almost ANY motor combo through inspection as long as you can pass the visual. If the rear 02 sensors are disabled, they will not produce emission codes, thus you pass.
Old Feb 9, 2006 | 05:58 PM
vettenuts's Avatar
vettenuts
The edit must be done correctly, and Don can do that. He is probably the best LS1 tuner in MA, at least that I know of and people come from NJ, PA and MD to have him tune their cars.
Old Feb 9, 2006 | 07:54 PM
screw991le's Avatar
screw991le
Miles has nothing to do with it, it is engine cycles
To Massachusettes Inspection
