Won't start after H/C install
Old Feb 10, 2006 | 06:36 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Default Won't start after H/C install
Tried starting after H/C,LS6 intake,UD pulley,3.73 gears.It tried to run a few seconds and popped a few times out the exhaust.Tried again and it just turns over,sounds like it wants to fire,but nothing. Checked a plug it was soaked with gas,pulled the relay for fuel pump so it wouldn't flood it out,tried to start,popped a few times but nothing.Checked compression on one plug,200psi,compression is good.Or should I checked all 8 cylinders? I dialed in the cam,dead nuts on,I got 1 code P1571 H C, What do you guys think?
Old Feb 10, 2006 | 06:47 PM
dpd's Avatar
dpd
200 psi? can't be.regardless,are you sure the valves aren't being held open? depending on your cam,maybe your pushrods are too long.i'm assuming the cam is timed right. 1571 set probably because the engine started while you were still holding it in crank.
Old Feb 10, 2006 | 07:10 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Its an old gauge,so it could be off.Whats normal compression?I'll check all 8 cyl. on Saturday.
Old Feb 10, 2006 | 07:43 PM
dpd's Avatar
dpd
depending on mileage-anywhere between 155-165.i'm assumng the bottom end is still original.are you sure the cam is timed right?
Old Feb 10, 2006 | 07:51 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Its a stock 97 bottom end w/14,000k miles on it.I checked the cam timing a few times before I buttoned back up.It was a degree or 2 off of what the paper said that the cam came with,so it can't be to far off. Is it possible it went to 200psi because the cylinders filled up with gas?
Old Feb 10, 2006 | 07:54 PM
dpd's Avatar
dpd
how did you adjust the valves?you should have adjusted them all in 2 crank revolutions.are you sure they not hung open?
Old Feb 10, 2006 | 08:02 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
There stock rockers,I went around when each one was closed and torqued them to 22 ft lbs.I'll recheck them tomorrow,now that you mentioned the valves may be hanging open,thats what it sounds like.I appreciate your help,Thanks............Paul
Old Feb 10, 2006 | 08:45 PM
dpd's Avatar
dpd
with 1 ready to fire[dots on cam don't line up]adjust both valves on 1,ajust the exhausts on 2-7-8,intakes on 3-4-5.spin it over[6 ready to fire],adjust both valves on 6,adjust the intakes on 6-7-8,exhausts on 3-4-5
Old Feb 10, 2006 | 10:43 PM
JC-5's Avatar
JC-5
This exact thing is happening to me, I'll be watching this closely as I'm stumped myself! I can get mine to start, but I have to crank, turn key off, crank, turn key off etc. and it will try to start and then finally catch. But there is popping out the exhaust until it smooths out. My plugs were saturated too. Anyway, hopefully we can get this diagnosed. Mine is a 99 FRC
Old Feb 10, 2006 | 11:00 PM
hightest's Avatar
hightest
Sounds like the valves are hung open.
Recheck you're rockers.
Hopefully you're cam isn't so big, or your pushrod length isn't off that you're valves are hitting the pistons.
Old Feb 11, 2006 | 08:52 AM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
I made up 2 valve checking springs and used my dial indicater,I had plenty of piston to valve clearence.I have stock length pushrods.I'm going to check compression on all 8 cyl. today and watch the snow come down
Old Feb 11, 2006 | 02:36 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
ttt
Old Feb 11, 2006 | 02:39 PM
dpd's Avatar
dpd
ttt
still having issues?
Old Feb 11, 2006 | 02:45 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Yes I am.Just want to see what somebody else thinks before I remove the front part of the engine and check the cam.
Old Feb 11, 2006 | 02:48 PM
dpd's Avatar
dpd
what did you come up with? recheck your faults.
Old Feb 11, 2006 | 03:01 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
It has fuel,spark & more than normal compression,Sssooooooo my guess is it has something to do with the cam timing.The other guy has the same problem,JC-5?I'm trying to PM him and somebody else,But I don't think PM's are working.Somebody has to have some idea.
Old Feb 11, 2006 | 03:05 PM
dpd's Avatar
dpd
i'm going to assume compression is ok and the pushrods are not holding the valves open.when you installed the cam,did you line up the dots or did you have them both going up at 12 o' clock?
if you take off both valve covers and bring #1 to top dead center to fire,both valves on #1 should be closed and #6 cylinder should be on overlap[end of exhaust stroke,intake valve should just be opening and the exhaust valve should be closing].if the valves AREN'T hung open,you probably are 180 degrees out of time,with the dots lined up #6 cylinder fires,with them both up at 12 o clock,1 fires.since there is no distributer the cam sensor and crank sensor have to match.with that being said,the valve adjustment would have to be off if you are 180 out also.
are you sure you don't have any faults? did you reattach the grounds on the back of the head[left one]?
To Won't start after H/C install
Old Feb 11, 2006 | 03:30 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
if you take off both valve covers and bring #1 to top dead center to fire,both valves on #1 should be closed and #6 cylinder should be on overlap[end of exhaust stroke,intake valve should just be opening and the exhaust valve should be closing].if the valves AREN'T hung open,you probably are 180 degrees out of time,with the dots lined up #6 cylinder fires,with them both up at 12 o clock,1 fires.since there is no distributer the cam sensor and crank sensor have to match.with that being said,the valve adjustment would have to be off.
I'm going to take the valve covers off and check what you said.I did line dot to dot,I'm pretty sure the cam is 180 out. I'll be back later and let you know.Thanks................Paul
Old Feb 11, 2006 | 03:40 PM
mowton's Avatar
mowton
It's been awhile for me, but aren't you supposed to turn over the engine for 2 Crank revolutions and verify the Cam/crank dots return in-line? This say's you are truly timed properly, and not 180 degrees off.
Old Feb 11, 2006 | 03:41 PM
dpd's Avatar
dpd
ok,if you lined it up dot to dot,#6 was firing[i think the manual has it like that].#1 is in overlap.i think you adjusted the valves 180 out.your cam is not out[it shouldn't really matter because there is no distributer,the cam/crank sensors know the difference from the reluctor rings on the cam/crank].but if you adjusted the valves thinking that the dots lined up was #1 firing then you adjusted the valves 180 out.
as long as i know chevy motors were always weird like that,#1 firing was cam/crank dots at 12 o clock.
