Dual Heater
Old Feb 11, 2006 | 10:57 AM
mustard's Avatar
mustard
Default Dual Heater
If the Drivers Heater is set at 70 degrees, how warm can the passengers side be on a 2004? I have to control the warmth on the passengers side with the drivers heater. Kinda defeats the purpose of the Dual Heaters.
Thank you
Gene
Old Feb 11, 2006 | 11:01 AM
cenzo's Avatar
cenzo
Gene, the driver's side control sets the temperature, the passenger control is just a plus or minus option - either hotter or cooler than the set temp. Is that your question?
Old Feb 11, 2006 | 11:20 AM
mustard's Avatar
mustard
Default Dual Heater
It's kinda the question. When I have the drivers side set where I like it,(say 70) the drivers side won't get any warmer. I have to keep turning up my temp so the passenger side will get warmer
Gene
Old Feb 11, 2006 | 11:25 AM
cenzo's Avatar
cenzo
Well I don't think that's right. Although the temp display will only display the drivers side set temp, the passenger side control should allow a warmer output for the passenger side. If it's still under warranty I'd get it looked at.
Old Feb 11, 2006 | 11:48 AM
mustard's Avatar
mustard
I did take it to a Dealer here in Spokane and I was told that the Heater for the passenger was controlled on the drivers side. I thought this was kinda strange. Why would they put in Dual Controls if the driver was going to control the heater. I wanted to find out what was wrong and then I could tell the Service Manager at the Dealer.Thank you for all your help
Gene
Old Feb 11, 2006 | 12:08 PM
DeeGee's Avatar
DeeGee
Thank you
Gene
This is from the manual if it helps. i think you only have a couple of degrees each way.
The PASSENGER **** changes the temperature on the
passenger’s side of the vehicle. When the **** is in the
12 o’clock position, the passenger’s temperature is the
same as the driver’s. Turn the **** clockwise for warmer
air on the passenger’s side, counterclockwise for cooler
air. If the driver-set temperature is set at 60F (16C) or
90F (32C), turning the passenger **** has no effect
Old Feb 11, 2006 | 12:14 PM
mustard's Avatar
mustard
Thank you...I read the Manual also, but the passenger side doesn't change much. Maybe your right about the couple of degrees either way.Gene
Old Feb 11, 2006 | 12:25 PM
TexasAg98's Avatar
TexasAg98
Cruise-In II Veteran
I thought it was +/- 4 degrees from what was set on the drivers temp gauge.
To Dual Heater
