electrical grounds on frame
Feb 11, 2006 | 03:51 PM
4th Gear
Can anyone tell me the proceedure (and locations) for cleaning the grounding terminals to the fram on a 1998 coupe model? Thanks.
Feb 11, 2006 | 10:19 PM
Quote:
Bill Curlee has a very good post here. Do a search of the Archived threads.
Feb 11, 2006 | 11:35 PM
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Don't know if it is exactly the same (I have an 02) but there is a ground from the negative terminal to the chassis right below the battery box.
There is a ground on the same run of chassis towards the front of the car.
There is a ground from the negative terminal to the passenger side of the block.
There is a ground on from the chassis to the block on the driver's side.
There are other various small grounds coming from harnesses but these are your mains.
Feb 11, 2006 | 11:52 PM
Feb 12, 2006 | 11:14 AM
4th Gear
Feb 12, 2006 | 11:15 AM
4th Gear
Feb 12, 2006 | 11:16 AM
4th Gear
Feb 12, 2006 | 01:15 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you need any ONE ON ONE help,,,, all you need to do is yell!! Us 98 C5 guys need to stick together
We need all the help we can get!
What exactly are you having issues with?
Bill
Feb 13, 2006 | 08:02 AM
SillQuestion . . .
For those of us electronically challenged; and since no one has already asked. . . is it wise to disconnect the battery before disconnecting and cleaning the grounds?
Just wondeing . . .
Feb 13, 2006 | 08:04 AM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES! That would be the correct and recommended way to do ground cleaning!! That way you won't get surprised by a spark and maybe damage something.
BC
