Anyone Use Rislone?
Old Feb 11, 2006 | 04:58 PM
Len16's Avatar
Len16
Default Anyone Use Rislone?
My second car (2001 Chevy Malibu) had engine valve noise and my mechanic suggested "Rislone Engine Treatment".
My Corvette (2000 Coupe) has some minor valve noise - especially on startup.
Anyone ever use Rislone (or equivalent) to eliminate minor engine noise in their Corvette?
Old Feb 11, 2006 | 05:16 PM
vettenuts's Avatar
vettenuts
Won't touch it. Cars use synthetic oil, Rislone isn't required or warrented. I do use Lube Control, but this is an anti-oxident for the oil.
Check over on Bobistheoilguy.com on the Rislone, I think you will find it is not a favored product at all.
Old Feb 11, 2006 | 06:10 PM
tsts's Avatar
tsts
Stopped using it in the late 60's along with STP and others; I think it used to be called Shalow Rislone or something like that. Old technology, not appropriate for Corvettes and most modern engines.
Old Feb 11, 2006 | 08:03 PM
vette2k1's Avatar
vette2k1
I didnt know that they still made that stuff. Like it says above, I wouldn't use it.
Old Feb 11, 2006 | 09:51 PM
Len16's Avatar
Len16
Thanks for all the information.
Old Feb 11, 2006 | 11:00 PM
Mikeceli's Avatar
Mikeceli
Wait a minute! Based on my experience and training, there is a place for Rislone.
I am not a fan of additives, but sometimes they serve a purpose. On a vehicle with a frequent oil change history, it is not needed. On higher milage(100,000 or so) vehicles, with ticking lifters and/or unknown service history, Rislone may help. I have bought several such vehicles and on two occasions, cured clicking lifters, with Rislone. If the problem is caused by sludge build up, Rislone in time, may cure the noise. I replaced one quart of oil, at an oil change, with Rislone and the noise soon went away. I continued using Rislone, for about 50,000 miles.
My 88 Lincoln Mark VII LSC, has 212,000 miles and I have added Rislone when I bought it at 80,000 miles. Never pulled an engine gasket and it runs like NEW.
Years ago, I bought a 1965 Lincoln approx. 90,000 miles, unknown service history. Also, leaded gas/carburated vehicles, tended to get a lot more sludge it thier crankcases. I pulled the oil pan an removed LITERALLY 3/8" tar like sludge, from the pan bottom. Inside the valve covers, I removed a lesser amount, of sludge. I started using Rislone and cured a lifter noise. Also continued Rislone till I sold the car. I didn't put many miles on it, maybe 20,000(wasen't practical). The oil appeared to be less dirty, at each oil change, so I know Rislone was working.
I would NOT add any additives, to a low milage synthetic oil vehicle.
God Bless America!
Old Feb 12, 2006 | 10:28 PM
hallenti01's Avatar
hallenti01
1st Gear
I Believe it was once called "Shaler Rislone"...
Old Feb 13, 2006 | 09:09 AM
MiamiCowboy's Avatar
MiamiCowboy
Snake oil.
Old Feb 13, 2006 | 12:15 PM
arcom's Avatar
arcom
1/4 Risolene
1/4 Marvel Mystery Oil
1/4 White kerosene
1/4 acetone
Best gun cleaner out there.
To Anyone Use Rislone?
