vararam velocity stack
Old Feb 11, 2006 | 06:31 PM
03ELECTRON's Avatar
03ELECTRON
Default vararam velocity stack
does any one know or have a varaRam Velocity Stack suppose to give ya 6-13 h.p. thanks
Old Feb 11, 2006 | 07:11 PM
coolz51's Avatar
coolz51
just pm'd you. thx, mike
Old Feb 12, 2006 | 12:07 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
More like .6 HP..
Old Feb 12, 2006 | 12:10 AM
dragon84's Avatar
dragon84
I own one....its in there...thats about it.
Old Feb 12, 2006 | 02:11 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
I have one and seems to improve throttle response. It takes the place of polishing the TB. As for any gains in hp, who knows? Lets say it gives you 5hp; there is no way to really measure it, even with a dyno. You can get 5hp differences with back-to-back dyno pulls with no changes at all. If I didn’t already have it, I would not buy one. But then again, I don’t think you get anything from polishing a TB on a relatively stock motor.
Clayton
Old Feb 12, 2006 | 02:15 AM
C5Generl's Avatar
C5Generl
more like - .6hp. i think it chokes my car in the upper rpms. i took that thing out, it's sitting in my trunk right now where its supposed to be b/c it has no place under the hood.
Old Feb 12, 2006 | 11:04 AM
DngrZne's Avatar
DngrZne
I have one, but I removed it and ported and polished the throttle body myself. I believe that to be a better way to improve the airflow through the throttle body. The velocity stack actually has a smaller opening and the one end then the TB itself. I just couldn't bring myself to use such a cheap piece of junk in the car.
Chris
Old Feb 12, 2006 | 01:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you cant port & polish your own TB, the stack might be something to consider. It smooths out the air flow. I had both options to consider. Port my own or install the stack. I ported mine!!
BC
Old Feb 12, 2006 | 01:36 PM
Cgillies86's Avatar
Cgillies86
In my opinion every little bit helps. Even, the coolant bypass through the throttle body did something....well, maybe it did.
To vararam velocity stack
