Pcm Reset
Old Feb 15, 2006 | 12:07 PM
INTHERED's Avatar
INTHERED
Default Pcm Reset
Sometimes when I start my car my PCM gets reset and yes I do have
a new battery that measures 12 volts with the key on and 14 volts with
the car running. Has anyone seen this problem ?
Thanks >>>>> INTHERED
Old Feb 15, 2006 | 03:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have a bad connection some where that is allowing the PCM voltage to drop below the PCM's minimum voltage requirement. I would start with battery cables (clean and torque the cables on the battery to 12 ft/lbs) and then clean the grounds. Especially the PCM related grounds.
Bill C
Old Feb 16, 2006 | 11:06 AM
INTHERED's Avatar
INTHERED
Originally Posted by Bill Curlee
You have a bad connection some where that is allowing the PCM voltage to drop below the PCM's minimum voltage requirement. I would start with battery cables (clean and torque the cables on the battery to 12 ft/lbs) and then clean the grounds. Especially the PCM related grounds.Bill C
Well I checked the cables and connections and they are all good.
I looked in the shop manual and the PCM uses ground G106. Does
anyone know where this is located ?
Old Feb 16, 2006 | 01:27 PM
cliff_ford's Avatar
cliff_ford
G106
Engine harness, RH side of the engine, above the starter (CKT 451)
Old Feb 16, 2006 | 09:47 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep,,, I think it's a 15mm bolt and there will be TWO ground wires connected to it.
Old Feb 20, 2006 | 12:14 PM
INTHERED's Avatar
INTHERED
This 15mm bolt is it bolted to the block or the frame ?
Can I get to it from the top or do I need a lift ?
Old Feb 20, 2006 | 10:24 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are TWO ground bolts on the lower portion of the block. They are located just below (approx) # 3 and #4 cylinders sparkplugs. I have a picture of the bolt. Send me your e-mail address and I will send them to you.
BC
Old Feb 21, 2006 | 05:35 PM
INTHERED's Avatar
INTHERED
There are TWO ground bolts on the lower portion of the block. They are located just below (approx) # 3 and #4 cylinders sparkplugs. I have a picture of the bolt. Send me your e-mail address and I will send them to you. BC
Bill
Thanks for the information after spending several hours searching
thru my shop manuals last nite I finally found a drawing of the bolt
location in the starter removal section of the manual.
Mike
To Pcm Reset
