Head Bolts
Old Feb 17, 2006 | 09:00 AM
ksaieg78's Avatar
ksaieg78
Default Head Bolts
I'm In The Process Of Re Installing My Freshly Ported Ls6 Heads And Am Wondering If It Is In Fact Necc. To Replace The Head Bolts???? If You're Not Sure, Or Have Only Heard That
They Need To Be Replaced Please Don't Reply I Would Like To Know For Sure. What Do They Do At The Dealer???? Do They Replace Them????
Old Feb 17, 2006 | 09:12 AM
vettenuts's Avatar
vettenuts
Yes, you have to replace them. The Service Manual has a big warning on re-using them. The way they are tightened, to ensure proper preload, is to twist through an angle rather than a torque value.
Old Feb 17, 2006 | 09:32 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It is a FACT, that the head bolts MUST be replaced!!!! They are a Torque to yield bolt and designed to be a ONE TIME use fastener. Don't try to use them. They are inexpensive and easy to get.
They need to be torqued to 22 ft/lbs and then angle torqued to the correct degree.
If you reuse the old ones the angle torque specifications will not provide the correct clamping forces to work properly.
BC
Old Feb 17, 2006 | 09:59 AM
vettenuts's Avatar
vettenuts
Here is a basic article that will provide you some backgroud on the reason they are TTY for preload.
Enjoy
TTY Fastener Article
Old Feb 17, 2006 | 10:11 AM
ArKay99's Avatar
ArKay99
Also, I don't know if you are aware of this so I'm bringing this to your attention. The bolt holes have to be squeaky clean. No dirt, No coolant, no threadlock, from the uninstall. If the holes aren't cleaned perfectly, you will probably cause a hydrolock in the holes and crack your block. Let me refer you to this article on the way to do this properly. Head re-install . Scroll down to the section on prepping the block decks and bolt holes. It's really easy, just takes a little time, but prudent.
Best of luck.
Old Feb 17, 2006 | 01:43 PM
Jim Taylor's Avatar
Jim Taylor
Also, the dealer will gouge you for the ten main bolts, $6-$8 per bolt! Buy them from your local auto parts store or from an online parts house for $20-$25 per head. Same thing with the gaskets.
Old Feb 17, 2006 | 03:31 PM
IFLUBYU's Avatar
IFLUBYU
Yes it is a fact, you cannot reuse torque-to-yield bolts, which the factory ones are. I'd recommend replacing them with ARP bolts or studs, which are reusable. Very good point on cleaning the bolt holes, also you do not get accurate torque readings if there is dirt on the threads.
Old Feb 17, 2006 | 03:36 PM
Heretic's Avatar
Heretic
I'd pay the dealer price before I bought parts store junk. Beans has them for cheap though.
Also there is option B which costs a bit more, but is the best option. ARP bolts. I will never ever buy anything else after having a GM head bolt break at its specified torque while building a BBC.
Old Feb 17, 2006 | 04:51 PM
vettenuts's Avatar
vettenuts
Yes, I am going with the ARP 12 point studs.
To Head Bolts
