Visor Removal - How is it done?
Old Feb 26, 2006 | 02:34 PM
2GOFAST's Avatar
2GOFAST
Default Visor Removal - How is it done?
Want to remove my driver's side visor (2004 coupe) to add a homelink tranmitter.
How do I remove the visor from the car?
Old Feb 26, 2006 | 02:55 PM
G-lock's Avatar
G-lock
Check the Tech-Tips section, good luck, about 2 in 5 break them removing them. Short answer, put a screwdriver in the slot and use the shaft of the visor to turn the bezel. I destroyed mine!. Jeff
Old Feb 26, 2006 | 03:41 PM
2GOFAST's Avatar
2GOFAST
Thanks,
I printed out the how-to and will try to remove it tonight. I appreciate the warning about breaking the bezel - i will be very careful.
Old Feb 26, 2006 | 03:43 PM
SMR 67's Avatar
SMR 67
Also be careful disconnecting the wire. There is a small gray clip that you need to squeeze or fiddle with - go easy on it but you'll get it.
By the way, where do you get the home link transmitter?
Old Feb 26, 2006 | 04:28 PM
2GOFAST's Avatar
2GOFAST
Got the transmitter on e-bay. It is from a 2005 ford tarus visor. Paid about $30 with shipping for the entire visor (driver's side only).
I was bidding on a volvo visor with the homelink and the price got up to $45 and climbing. Got out of that and found the ford at an auction that was about to end. I was the only bidder and got it for the initial bid price. The lesson I learned is to go for a visor from the more common and less expensive car to get a good price.
Do a search for "homelink" and a lot of auctions should come up.
Good luck and thanks for the advise on the electrical connection.
Old Feb 26, 2006 | 06:33 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Sun Visor Removal Instructions
Old Feb 26, 2006 | 09:37 PM
ALLEGRO's Avatar
ALLEGRO
Originally Posted by navy99vert
Boy you can learn a lot if you will read the posts.
Tech Tips are the BOMB
To Visor Removal - How is it done?
