HELP-Fuel Pump is Causing No Start Condition
Old Mar 1, 2006 | 11:58 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Default HELP-Fuel Pump is Causing No Start Condition
Car cranks but will not catch. Fuse is fine, voltage is getting to fuse box. Fuel pressure is zero. Pump does not make noise like normal when in "on" setting. No codes. Anything else I can check before I get a new pump?
Old Mar 2, 2006 | 12:01 AM
turboc5's Avatar
turboc5
Fuel pump relay and the plug at the tank. If you put your hand on the relay while somewone else turns the key you "should" feel it click. You could also swap the relay with another one that looks exactly the same. Ex. maby a horn relay or somthing?
Old Mar 3, 2006 | 08:32 PM
ICaughtVetteFever
Swapped with the AIR pump system relay and car started right up. Can't believe I forgot to check the relay, thanks turbo. I removed the AIR pump system from my car so I did not even have to buy a new relay
Old Mar 4, 2006 | 07:52 PM
turboc5's Avatar
turboc5
Good to hear
Old Jun 4, 2006 | 11:35 PM
Sammy_C5's Avatar
Sammy_C5
To HELP-Fuel Pump is Causing No Start Condition
