Techron harmful to injectors??
Old Mar 3, 2006 | 11:12 AM
jj_adams319's Avatar
jj_adams319
Default Techron harmful to injectors??
Took my 98 C5 (31k on the clock) to the dealership for intermittent hard starting.
Mechanic found 2 leaky injectors (5&6).
The mechanic had asked if I had used any additives...I replied with yes, used Techron twice in the last 6k miles to correct my gas gauge problem (which it had). Mech. suggested Techron may be at fault for
the bad injectors.
Just wondering if there is any truth to this theory, since many forum members here use this additive w/out any issue?
Thanks in advance for your replies.
Jason
Old Mar 3, 2006 | 11:18 AM
Bubbletop409's Avatar
Bubbletop409
I put a bottle in the 34 gallon tank on my GMC dually, and it made my " service engine soon " light come on and stay on for two more tanks full. Must have some powerful ingridents. One bottle in our 18 gallon tank would be twice as concentrated.
Larry
62 Bel-Air 409
260 Eagle XP HP500EFI
2002 Corvette M6 Coupe
Old Mar 3, 2006 | 11:21 AM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
the bad injectors.
Jason
In fact GM actually uses techron in their fuel system treatment (part#88861011) and recommends using it on a regular basis. I would have to say that if it was bad for the injectors GM would not use it. The label even reads: "removes deposites from injectors which can restrict fuel flow and cause improper fuel injector operation."
Old Mar 3, 2006 | 11:29 AM
binkysgarage's Avatar
binkysgarage
I hope not, dumped a bottle in yesterday.
Old Mar 3, 2006 | 11:30 AM
jj_adams319
That's what I said.
Mech seems to think techron is more for coating than it is for cleaning.
I tend to disagree.
Old Mar 3, 2006 | 11:44 AM
WKMCD's Avatar
WKMCD
the bad injectors.
Jason
There are a lot of people here using Techron regularly in their cars and I've not heard of a single case of injector failure caused by it.
I'll be the first one to call
Old Mar 3, 2006 | 11:52 AM
SLPRC5's Avatar
SLPRC5
I use Chevron gas exclusively and have used Techron without injector problems. Find another mechanic.
Old Mar 3, 2006 | 11:58 AM
azmusclecar's Avatar
azmusclecar
Originally Posted by RstyNutz
I use Chevron gas exclusivly and have used Techron without injector problems. Find another mechinic.
Old Mar 3, 2006 | 12:04 PM
wt2ga's Avatar
wt2ga
Old Mar 3, 2006 | 12:10 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Old Mar 3, 2006 | 12:11 PM
RED99's Avatar
RED99
Ask him if this is his "theory", or if he has hard data to back it up?
I think you just need to take it out and run the crap out of it at WOT for a while.
Old Mar 3, 2006 | 12:24 PM
RichieRichZ06
St. Jude Donor '08
That's what I said.
I tend to disagree.
Tell him to read the bottle and see if he still thinks the same thing. I'm sure they have a few on their shelves.
Old Mar 3, 2006 | 12:44 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
We stand united on Techron GM uses it in their service bays daily.
Old Mar 3, 2006 | 12:53 PM
hhntr111's Avatar
hhntr111
I use it in all our cars, no problems, just nicely running engines.
Old Mar 3, 2006 | 01:34 PM
The Wrench's Avatar
The Wrench
I'm a fan of Techron, and use it a lot - but not in the Vette.
I figure I get enough in the Chevron fuel.
But, I do remember reading somewhere about it not being recommended for the Vette injectors. I wonder if it was on this forum?
You might do a search. But as you guys said, lots of us use it all the time.
One ancedote; on my Mercedes forum one of the guys put an additive, (not Techron, BG I think) in his CIS-injected engine, and clogged the tiny injector filter screen with debris that the additive broke loose.
Old Mar 3, 2006 | 01:39 PM
jimmie jam's Avatar
jimmie jam
techron bad?????
Old Mar 3, 2006 | 01:52 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
its in Chevron gas. So if you told him you used chevron gas, hed tell you the same thing? hes trying to let you avoid warranty so the dealer can make money off you.
To Techron harmful to injectors??
Old Mar 3, 2006 | 02:09 PM
RichieRichZ06
St. Jude Donor '08
the dealer WILL make money on warranty also. I think the dude was just too stupid to know what he was talking about
Old Mar 3, 2006 | 02:34 PM
vettenuts's Avatar
vettenuts
There was an issue with it removing insulation on the L-98 injectors, but it resulted in an electrical problem. Haven't heard of this since.
Old Mar 3, 2006 | 02:57 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I put it in my DD and got a check engine light.Something with the fuel guage.
