MAF Cleaning
Old Mar 4, 2006 | 06:04 PM
mowton's Avatar
mowton
Default MAF Cleaning
Is there a proper way to clean the wires and sensors in the MAF. I know they are very fragile and should not be touched.
Is it necessary to clean them? Mine look "dark" and I was wondering if that effects performance at all.
Ed
Old Mar 4, 2006 | 07:01 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Do not touch them or use any cleaner with a q-tip...
the best way to clean them is with electrical contact cleaner.
Just spray it on allow it to air dry.
Old Mar 5, 2006 | 09:17 AM
rws.1's Avatar
rws.1
I have also successfully used throttle body cleaner and brake cleaner.
Any aerosol solvent based cleaner that removes oil and grease and then evaporates will do the trick.
If you are going out to buy it, buy the electrical contact cleaner. If you have one of the others at home, save yourself the trip.
Old Mar 5, 2006 | 11:00 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BC
Old Mar 5, 2006 | 11:21 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
This will be what I use next time.
Micah
Old Mar 5, 2006 | 12:43 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
we used this stuff called 'trichloromethane'? it was pronounced trike in the air force, sounds like the same stuff
Old Mar 5, 2006 | 06:54 PM
Evil-Twin's Avatar
Evil-Twin
Connecticut !!!! that stuff gives you brain damage how long were you in the AF????
Old Mar 5, 2006 | 07:06 PM
SteveDoten's Avatar
SteveDoten
94-05, we have all the good stuff, got injected w/ antharax and smallpox also
Old Mar 5, 2006 | 07:18 PM
Redspark's Avatar
Redspark
Cruising
A clean MAF WIRE will return the A/F ratio to where it belongs. When it is coated it signals a lower air flow and the computer leans the mixture. It should be one of the first things you check if response is sluggish and you have over 40k miles
Old Mar 6, 2006 | 12:14 PM
RDVT4ME's Avatar
RDVT4ME
Is it OK to clean it while still on the car or must you remove it first?
Old Mar 6, 2006 | 01:15 PM
tboneinsc's Avatar
tboneinsc
CN I think that is TrifloroTricloroEthane. Methane is what the crew dogs released after lunch! We ex AGE guys gotta keep an eye on you crew cheifs!
Old Mar 6, 2006 | 04:29 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its a good thing that he already posted a reply to your question!! I was going to reply "HE DOESNT REMEMBER!!"
BC
Old Mar 6, 2006 | 09:35 PM
SteveDoten's Avatar
SteveDoten
AGE(aerospace ground equipment for the lesser civilians ) i think you are close, Trichloroflouromethane
i need a B-4 at the end of the ramp and the -60 won't start
Old Mar 6, 2006 | 09:36 PM
SteveDoten's Avatar
SteveDoten
CT not CM, know your states
Old Mar 7, 2006 | 01:25 AM
PierEagle's Avatar
PierEagle
Several years ago, "trich" use to be used alot. But I'm pretty sure it was later banned because it is a pretty heavy duty carcinogen.
Old Mar 7, 2006 | 07:51 AM
tboneinsc's Avatar
tboneinsc
I wonder if I can get one of those -60 engines in the Vette? Hmmmm
Old Mar 8, 2006 | 12:14 AM
Bob25thTA's Avatar
Bob25thTA
CRC also has a cleaner specifically for MAF cleaning.
http://www.crcindustries.com/auto/co...x?PN=05110&S=N
To MAF Cleaning
