Oil Change
Mar 4, 2006 | 06:12 PM
Oil Change
Changed oil and used 10w30 instead of 5w30,any one see a problem with this,started but haven't driven yet,thank's .
Mar 4, 2006 | 06:27 PM
The issue will be cold temperature starts and oil not getting to remote engine parts as quickly. I believe the General says 5W30 is preferred but 10W30 can be used as long as the temperature is not below 32F...
BUT check your manual....
Mar 4, 2006 | 06:32 PM
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I use 5w-30 during winter time because its thinner and is better during cold starts.
Mar 4, 2006 | 07:07 PM
The service manual says that 10W30 can be used as long as the temperature is not below 0 deg. F.
You can go to 0W30 if it is going to be below -20 deg.
5W30 is recommended because it is acceptable in any temperature range.
Mar 4, 2006 | 07:59 PM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
been using 10W30 here in Fla since the car passed 30K....no issues...72K now...
Mar 4, 2006 | 10:26 PM
St. Jude Donor '06-'07
If it were me, I wouldn't worry about it.
Mar 4, 2006 | 11:40 PM
10W30 Royal Purple and K&N oil filter HP1007...no issues 58K miles on '97
Mar 5, 2006 | 12:37 AM
Why don't people read their owners manuals?
Mar 5, 2006 | 02:43 AM
Mar 5, 2006 | 04:20 AM
Quote:
why did you reply?
FWIW the manual doesn't address this issue per se....all it says it to use oil that meets the following standard/specs GM 4718M
Mar 5, 2006 | 03:44 PM
But the owners manual does talk about oil temps.
Mar 5, 2006 | 06:17 PM
St. Jude Donor '03-'04
it is important to have oil in the motor
Mar 5, 2006 | 06:22 PM
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Quote:
Mar 5, 2006 | 06:54 PM
What is the purpose of this forum then???
Mar 5, 2006 | 07:08 PM
Good Question... my guess is some people may not have them.. alot of times people keep them when they sell or trade the car. Plus it's more fun to make posts and get everyones opinion on what they should do with there car.. LoL
-=Rick
Mar 6, 2006 | 04:54 AM
yeah but then they would have to know which oil for which temps
which would require more reading...
you're getting ahead of yourself...
Mar 6, 2006 | 11:28 AM
I always keep oil in my motor.
Mar 6, 2006 | 12:18 PM
Premium Supporting Vendor
Quote:
Just keep in mind that a 10w30 is going to be a little more viscous at startup until the oil is well over 100F than a 5w30. Be gentle with it until the oil is good and warm and you'll be fine.
Mar 6, 2006 | 12:40 PM
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
I have ALWAYS run 10w30 and no problems yet!!!!
Mar 6, 2006 | 01:11 PM
I always keep about 6.5 quarts in the engine just for good luck. Seems to work better than a lucky rabbits foot.
