Changed oil and used 10w30 instead of 5w30,any one see a problem with this,started but haven't driven yet,thank's .
Good question! Owner's manual will not tell you a little trade secret of the oil companies. The smallest molecular structure of synthetic oil base stocks ( mobil 1 included) is 10 grade. To get the 5 grade, one adds viscosity improvers that do nothing for lubricity. The 5 grade simply helps the engine achieve the CAFE ratings.
Do what I and most every other autocrosser out there do, use the 10-30 grade and enjoy your vette for many thousands of trouble free miles.
While I agree that they use a 5w for CAFE ratings, I think your description of the Viscosity Improvers (VI) is a little off from what I've read.
With conventional oils, an SAE 10 weight is within the 10 weight catagory when cold and as it heats up, it stays within the 10 weight catagory. Keep in mind that the viscosity of a hot (212F) 10 weight is much lower than the viscosity of a cold (100F) 10 weight. Our engines need a 30 weight when hot. Good synthetics have a naturally high viscosity index, thus as a 10 weight synthetic heats up it doesn't thin out as much and stays in a 30 weight catagory. 10w30 synthetics probably don't need any VIs meaning they are much less susceptible to viscosity shear and thinning low out of grade. A 5w30 will need VIs. When cold, these VIs coil up. At higher temps, they uncoil to help make the oil retain its viscosity as it heats up. As they break down (shear down), you are left with the properties of the base oil, a 5w, when cold, but as it heats up without all the VIs present, it won't retain enough viscosity to be a 30 weight and could for example become a 5w20.
Subdriver, I think there might be a correction or two in order here. There is no 'weight' designation for oil...only 'grade'. As far as 10-30 grade, by definition the companies have to use VI's to span the different grade classification from 10-30. There is no 5 grade base.
On the grade vs weight, you are correct and I should have been more specific. But, the SAE added SAE 5W to their grade classification in 1950. And, from what I've read, Group IV or V synthetics have a high natural viscosity index and require less VI than petroleum oils do.
very nice information fellas. so, do i still put oil in my engine?
I live in Texas and have never put anything buy 10W30 in my cars.
Unless it starts getting below zero degrees in Texas and Florida, you should be alright.
I should have been a little more specific on the 5w grade. There is no 'base stock' that is 5 grade. The thinnest base stock is 10 grade. To obtain the 5w grade behavior from the oil, one must dillute the heck out of it with VI's. That is the reason a great deal of autocrossers stop at 10 grade on the low side of the grade rating, ......manufacturers 5w recommendation be damned! Not in my car. As I stated above, simply put in a synthetic (Mobil 1) 10-30 and drive it.
Oh yeah, possibly the reason fewer VI's are needed in syns is because the molecules are uniform in the syn base whereas the dino oils are an average (or median) of the different dino molecule sizes to ascertain a certain grade.
