Active Handing issue
Old Mar 7, 2006 | 08:40 AM
Mickbee's Avatar
Mickbee
Default Active Handing issue
Over the weekend I fired up my Z06 and the DIC indicated the car was in COMP mode. Shortly thereafter, it started cycling through the various modes on its own.
I clicked the button a few times to ensure it wasn't stuck, causing the cycling.
After a while it stopped cycling and when I attempted to shange mode, the button was not functioning. I took the Vette out to determine if this was a calibration issue or somethign to correct itself. The AT button has not responded.
Has anyone experienced this behavior?
How can I pull the codes to provide addtional info to the forum?
The car had been sitting for a while so I wonder if the battery was weak. I know, I know, "You have to drive it"...
Thanks in advance for your help!
Old Mar 7, 2006 | 09:06 AM
cliff_ford's Avatar
cliff_ford
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button to turn off any warning messages
3) Press and hold "options" and
4) While holding "options", press "fuel" four times within a 10-Second period.
Initially, the on-board diagnostics go into the "automatic" mode, which shows each module's DTCs in a
pre-set sequence: (Page No. are for the GM Service Manual)
10 PCNI Powertrain Control Module page 6-357 - 6-361
28 TCS Traction Control system ABS on page 5-86
?? RTD Real Time damping page 3-136
40 BCM Body Control Module page 8-405 LTD Page 8-727
60 [PC instrument Pane! Cluster page 8-508
80 radio page 8-213
99 FIVAC Heater Vent-Air Conditioning page 1-118
A0 LDCM Left Door Control module page 8-904 to 8-951
Al RDCM Right Door Control Module page 8-904 to 8-951
AC SCM Seat Control module page 8-1064-8-1082
B0 RFA Remote Function Actuation page 8-676
For each module, all DTCs will be displayed. If none are present in a module, you will see "no more codes" on the ICP display.
There are two kinds of DTCs, "Current" and "History," designated with a letter suffix, "C" or "H". A current code indicates that the malfunction is present in the system whose module is displaying data. A history code indicates a problem existed in that module sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it is possible it's evidence of a previous problem. Now solved, that was not removed by clearing codes. More likely is that a history code indicates an intermittent malfunction.
"Intermittent" are the most challenging DTCs. An intermittent may have happened only once, may have happened more than once but is inconsistent in its appearance or may be happening on a regular basis but not at the time the IPC is displaying codes. History codes can also be caused by a current malfunction in a system that is not Operating at the time DTCs are displayed. An example is the rear window defogger, which doesn't operate until the BCM detects engine rpm. For history codes set by a system that does not operate with the key on and engine off, a special diagnostic tool called a "scan tester is necessary to properly diagnose the malfunction.
Once the IPC has displayed all 11 modules, the system goes into the manual mode, which allows selection of each module, using combinations of DIC buttons. The manual mode can also be entered at any time during the automatic sequence by pressing any button except "E/M". Once the IPC displays "manual diagnostics", you may select a particular module by pressing the options button to go forward or the "trip" button to go back. Once a system is selected and a DTC is displayed, if more than one are present; press "gages" To move forward or "fuel" to go back. To exit the diagnostic mode at any time, press E/M". If you want to erase or "clear" codes, press "reset". Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory.
Old Mar 7, 2006 | 12:23 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
For the modes to change on their own, I would suspect one of the following things:
Wires for the switch (under the center console) are crushed and shorting together or to ground.
Ground for the EBTCM is corroded. (Grounds cause some crazy stuff to happen.)
EBTCM has a wiring harness or module issue. (That would be my last and least choice!!!! )
BC
Old Mar 8, 2006 | 07:45 AM
Mickbee's Avatar
Mickbee
Thanks for the info! I will run the tests this weekend.
I hope it isn't anything...
Old Mar 8, 2006 | 08:43 PM
jw38's Avatar
jw38
St. Jude Donor '14,'18,'21
OK Steve...the question is which one? You have 3 of them! I'm assuming it wasn't the Z16 and I doubt that your significant other would let you anywhere near hers so...it must be the black one!!! Yup, like you said...you gotta drive 'em!!!
Old Mar 8, 2006 | 09:38 PM
Mickbee's Avatar
Mickbee
The black is hers and the rest are mine. Actually, they are all mine; I just let her think the black is hers!
Oops, got to go here she comes!!!
P.S. I had the Coupe's windows tinted. Now I'm pimpin!
Old Mar 9, 2006 | 05:02 PM
jw38's Avatar
jw38
Oh yeah...the black one IS hers! Soooo...it must have been the yellow one!!! And you ARE a pimp!!!
Old Mar 9, 2006 | 10:48 PM
Mickbee's Avatar
Mickbee
The coler of the Vette has been changed to protect the...
I drive a Cadillac, I wear a perm 'cause I'm a "G"...
Old Mar 9, 2006 | 10:54 PM
Mickbee's Avatar
Mickbee
BC
Bill,
If the EBTCM has a wiring harness or module issue, do you know what causes it?
Is the module located below the battery tray? I haven't had a chance to see if anything leaked on it.
The car has very low miles and has never been in the rain and hadn't been driven or started in approximately 30 days. Prior starting it, I wondered if the battery would be dead.
Could a low battery condition be a potential cause? Or could it cause a short or surge?
thanks to all for your help.
Steve
Old Apr 4, 2006 | 06:42 PM
Mickbee's Avatar
Mickbee
Thought I would get back to everyone with the outcome...
It wasn't the car. It was the low battery. I threw it on the charer for a day and all is well.
As a result I ordered three more battery tenders to ensure all Vettes are fully charged.
Thanks for your help!
Old Apr 5, 2006 | 01:52 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Haaaaaaaaaaaa! I was reading the post and was thinking "man that dude could have a bad or discharged battery!!!
Cool!!!! keep that battery charged!!!!!!!!!!!!!
BC
Old Apr 5, 2006 | 06:16 PM
Mickbee's Avatar
Mickbee
BC
I didn't know whether to laugh or fall on the ground. I did NOT want to bring my Vette in to the dealer...
To Active Handing issue
