DIC wiring
Old Mar 8, 2006 | 02:07 PM
tjcleary's Avatar
tjcleary
Default DIC wiring
ok...i pulled out the instrument panel to see what the problem with my DIC may be. it doesnt appear to be unplugged or anything. now with a power tester i can see that every wire has power to it except one. the purple one read nothing, not a power or a ground wire. now, all the rest are power except for the gray one, its a ground, im assuming that is normal.
does anyone by vhance know what the purple one should be?
the vette is a daily so it needs to go back together now. but, my question pertains to what i need to do next.
get another DIC setup, or trace the purple wire back to where something is wrong.
thanks in advance for any help.
Old Mar 8, 2006 | 03:27 PM
cliff_ford's Avatar
cliff_ford
I think purple wires are Data Link.
Old Mar 9, 2006 | 12:02 PM
tjcleary's Avatar
tjcleary
so that one isnt important? so if all the other wires are positive or ground then it must be my DIC that is fried?
Old Mar 9, 2006 | 12:30 PM
cliff_ford's Avatar
cliff_ford
Not so sure about that. Bill Curlee is the man to drop a PM to.
Old Mar 9, 2006 | 01:25 PM
tjcleary's Avatar
tjcleary
thanks cliff
Old Mar 9, 2006 | 04:52 PM
SpeedyZ's Avatar
SpeedyZ
Did you open the Instrument Panel Cluster (IPC) or are you checking the plug on the back of the IPC? As far as I can tell the DIC is not controlled by any of the wires on the back of the IPC, it is controlled internally inside the IPC so you will have to open up the IPC to see what the problem is. I say this because I have monitored data in and out of the IPC and do not seen to see any DIC data in that stream.
The DIC is a Vacuum Florescent Display (VFD) which is basically a tube and normally require over 100 volts to operate the display. Most likely if a VFD will not light it is a problem with it's power supply. The display will have an inverter type power supply that will bump the 12VDC up around 100 volts to run the display. It is high voltage but very low current supply. No volts, no display.
If everything else on your IPC works OK like gages and lights then your problem is probably internal in the IPC.
Good luck
Old Mar 9, 2006 | 05:11 PM
tjcleary's Avatar
tjcleary
ok sorry thats my fault for not explaining it correctly.
the display works. the DIC buttons do not, the ones on the right of the speedo and stuff. the cluster that says fuel,gauge, E/M, Reset and so forth. those buttons do not work.
Old Mar 9, 2006 | 05:43 PM
SpeedyZ's Avatar
SpeedyZ
Oh OK, DIC works, just no control. That should be easy to figure out then. Best I remember there is some kind of light sensor in that switch so that may be the unknown wire. I will look in the manual a little later but I don't think they list much for those side cables as far as wiring.
With the cable hooked up try using a straight pin and sliding it down in the back of the connector beside the wire and checking for volts on each pin while pushing each button. The buttons will probably ground each pin as you push buttons, but you will probably have to have the cable hooked up on both ends before you can see exactly what it is doing. Write down what you see each pin/wire do and you will quickly figure out the switch.
Old Mar 9, 2006 | 06:09 PM
tjcleary's Avatar
tjcleary
that makes since. so you think the buttons themsleves are not functioning. makes sense. now i just need to ge tthe time to do that. i should have thought of that when i had the panel out, i only took readings with a power probe (pos or ground) , but only on the harness.
i am assuming that it is the buttons that are at fault, not the harness, as it does have some sort of power going to it.
Old Mar 11, 2006 | 02:21 AM
SpeedyZ's Avatar
SpeedyZ
Here is the diagram for the DIC wiring. It is much better than I thought it would be from what I remember the same HUD wiring cable details was very slim. Anyway, it appears if your wiring colors are the same you should be able to short the Gray and Brown wire and have it to toggle between gages. It looks like if anything happens in the switch (or harness) to break the ground then all buttons will quit working. Since you have voltage on the lines my guess is probably 85% chance bad switch and 15% bad cluster. Short that gray and brown wire and you will know really quick! If it is the switch you can probably open it up and fix it. It has to be a pretty simple switch.
If shorting the gray and brown does not cause the gauges to toggle, then hook up the switch and harness and probe for volts on the brown wire while you press the gauge button. If it goes to 0 volts and the gauge don't toggle your IPC is bad. If it don't go to 0 check the gray wire and make sure it don't come up from 0 when you press the button. If the gray wire comes up then your IPC is not holding the gray wire at ground and you can probably wire it to ground and fix the problem.
Good luck
Old Mar 11, 2006 | 10:01 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Do you have 5 VDC input to the switches and can you see the different voltages when you test each different switch??
BC
Old Mar 11, 2006 | 11:23 AM
tjcleary's Avatar
tjcleary
i dont know yet. i only had a test probe when i did this. i will test the voltage of each next.
hopefully its a simple fix and ill be done with it soon enough.
Old Feb 11, 2024 | 07:03 PM
Draven Harrison's Avatar
Draven Harrison
3rd Gear
Default Same issue
BC
hey how are y’all doing? Having similar issues with dic. Unplugged harness that runs from back of IPC to DIC and tested volts on the dic connector. Used grey as ground obviously. These are the results
purple- 5v
orange-10v
brown-10v
white-10v
green-10v
red-10v
blue-10v
yellow- said 0 at first then saw 8.1v
black-11.1
trying to track this down would appreciate any help! Dic lights up but buttons don’t work. Also have tested 2 dic controls and nothing changes
Old Feb 11, 2024 | 07:15 PM
redzg's Avatar
redzg
The history of DIC issues has pointed to resolution by replacing the IPC.
yeah, not the fix we all hope for.
Old Feb 11, 2024 | 07:29 PM
Draven Harrison
3rd Gear
I figured as much, just got a c5 and trying to fix the little things here and there, just wanted to see if there was any other possibility besides a whole new clusters. Some of the dic harness wires were in fact loose on the dic connection side but fixed those still nothing.. tested volt on all wires and that where I am now.
Old Feb 11, 2024 | 08:57 PM
redzg's Avatar
redzg
I have a spare cluster and a spare set of DIC buttons. Another thread recently pointed out the IPC wiring and the correct connector, so I'm trying to fab a bench harness so that I can maybe test the spare before going to all the trouble to swap it in. If it works and I swap it in, then I'm going to try to power up the original cluster and see if I can find anything like a missing or loose ground or similar. I worry, of course, about the high voltage in the inverter, so who knows where it will end up.
Old Feb 13, 2024 | 06:47 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NOTHING in the car runs off 10 vdc.
What is the battery voltage reading at the battery??
What is the voltage reading on the IPC FUSE??
There are two test points on all your fuses. Read both test points to ground and see if you are reading the full battery voltage on the fuse. I also recommend load testing that fuse and measuring the voltage to insure it isnt dropping low under load!
Bill
To DIC wiring
Old Feb 19, 2024 | 11:25 AM
Draven Harrison
3rd Gear
Bill
I have not tested all that yet. Going to test it when I get home today. Still learning electrical and new to these c5’s. Ran a code scanner and got a code for switch 6 short to ground. Not sure if that has something to do with the DIC not working or just a bother symptom of it.
Old Feb 19, 2024 | 04:27 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
SWITCH 6? Please list the exact code description. BCM CXXXX H, C, HC etc...
You do NOT need scanners to read codes for C5
Follow this video: How To Read C5 DTCs Using Internal Code reader: how to read c5 corvette codes - Google Search
Old Feb 19, 2024 | 05:19 PM
Draven Harrison
3rd Gear
I know you can use the DIC control to pull codes on the car. Also the car has an updated 0411 pcm since it’s a 97’. But since I couldn’t use the DIC control to look at codes I connected a scanner. The DIC code was IPC code B1537-00 Driver information center (dic) switch 6 signal short to gnd. As I said none of the DIC buttons work and I have changed out the dic control AND checked all DIC harness wires for good connection. When I checked the dic harness wires individually with a volt meter the results were as I said before in an above post. Figured as everyone said a new cluster is needed. But trying to check anything else I can.
