Trailer wiring
Old Mar 12, 2006 | 10:30 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Default Trailer wiring
I have all the stuff to wire the actual trailer, but where do I start on the car?
Old Mar 12, 2006 | 11:08 PM
chocoholic's Avatar
chocoholic
You can tap in behind the tail lights or the rear number plate, assuming we're on the same wavelength. Then you'll also see where to route the wiring.
Old Mar 13, 2006 | 05:01 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
for your Vette??
hmmmm............http://forums.corvetteforum.com/show...ybrid&t=770361
this page shows everything..wiring harness etc...
http://search.cartserver.com/search/...t2217&GO=GO%21
Old Mar 13, 2006 | 07:23 AM
tnsyty's Avatar
tnsyty
Yeah, you fit in well here in TN, we put trailer hitches on everything!
Old Mar 13, 2006 | 08:21 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Old Mar 14, 2006 | 08:25 AM
87bob's Avatar
87bob
Veteran: Coast Guard
Originally Posted by pewter99
for your Vette??
The first link does not work!
Old Mar 20, 2006 | 11:42 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Thanks man!
Old Mar 20, 2006 | 12:55 PM
pewter99's Avatar
pewter99
Originally Posted by 03Ragtop
Thanks man!
no problemo....still up in the air about making the trip to Nashville....I'll let ya know...
pewter99's Avatar
pewter99
hmm..just tried it..worked here
Old Mar 23, 2006 | 08:41 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Ok, on the car I have a wire for the taillights, one for each turn signal, and one for the brakes. On the pigtail, I have a wire for the taillights, and one for each turnsignal, and none for the brakes. What do I connect where?
(God I hate electricity )
Old Mar 23, 2006 | 09:34 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you don't have euro taillights, the turn signal wires from the car are the brakelights too.
Typically, treiler connections are...
Brown = taillight. Tap the harness to one of the taillight wires on the car.
Green = Right turn and braklight Tap the harness to one of the right brake/ts wires on the car.
Yellow = Left turn and brakelight, same as above, but tap into the left side.
White = ground, connect to frame or existing ground point..
If you have euro tails with seperate brake and turnsignals, you'll need a 3 wire to 2 wire adapter (commonly available at a parts store), unless you feel like fishing a wire up to the dash for this.
To Trailer wiring
