DIC Code P0300 and sputtering
Old Mar 13, 2006 | 11:07 AM
gt-hunter's Avatar
gt-hunter
Default DIC Code P0300 and sputtering
Ok so the car is sputtering bad and actually shuts off if I let it idle...It generated the P0300 code but doesn't tell me anything else. I recently got the P0200 (Injector Control Module) and got that taken care of. I looked at it and didn't see anything out of the ordinary.
Plug cables look good and so do the plugs (I didn't pull them)....
Does this sound like a bad coil pack, injector or could it simply be a plug?
Just want to get opinions so I can start pulling plugs and look at it before I wind up taking it to the dealer.
Anyone with previous experience just chime right in...
Mike
Old Mar 13, 2006 | 01:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There could be a couple of things that cause your misfire:
The wires are spiral wound and have a specific resistance value: The OEM GM wires should read 250-750 ohms. They should not have any tears/burns or rips in the boots or wire insulation.
Also check the connections inside the wires for nasty corrosion!! There should be NONE!!
You could also have a cracked insulator on the spark plug. (been there,, had that!! )
Check the wire resistance and plugs.
If you have to get new wires, you cant go wrong with the GM High Performance RED wires!!!!
Bill Curlee
Old Mar 13, 2006 | 05:22 PM
gt-hunter's Avatar
gt-hunter
Thanks Bill,
The wires are actually brand new. Just bought them when I installed the headers a couple of months ago. They are the OEMs and they look intact. I checked the inside of the connectors and didn't notice any corosion.
I don't see any smoke out the back when the car is on...just a weird situation.
Keep 'em coming if you guys have any idea.
Mike
Old Mar 13, 2006 | 05:47 PM
jers98vet's Avatar
jers98vet
A dirty MAF will show the same symptoms you have. It's easy enough and cheap enough to clean.
Old Mar 13, 2006 | 06:05 PM
dpd's Avatar
dpd
check the harness that goes up and over the left head.usually the harness rubs through creating the P0200[injector driver circuit].
Old Mar 13, 2006 | 06:51 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
*QUOTE"
This is where I developed a serious engine miss. I found that I had a cracked spark plug insulator that would leak voltage under power and run smooth as a kitten idling and light cruising!
I have a picture of the plug:
You can see the fine vertical crack!!! I could hear mine arc if I reved it up slightly but to find it I had to remove each plug and check them.
I recommend removing the plugs and looking for cracks especially around the area where the porcelain meets the metal base.
BC
Old Mar 14, 2006 | 09:45 AM
gt-hunter's Avatar
gt-hunter
Originally Posted by Bill Curlee
*QUOTE"
pic removed for reply
BC
Thanks Bill...I'm going to pull the plugs today and see what I find.
Thanks,
Mike
To DIC Code P0300 and sputtering
