Wich loctight
Old Mar 16, 2006 | 03:41 PM
bops90's Avatar
bops90
Default Wich loctight
I have the caliper brackets off on the front end, what color loctight do i need for the two large bolts? I have red.
Thanks Mark
Old Mar 16, 2006 | 04:05 PM
SynistrC5's Avatar
SynistrC5
I used red 242 on mine last time.
Old Mar 16, 2006 | 04:15 PM
bops90's Avatar
bops90
Thanks!!!! Mark
Old Mar 16, 2006 | 04:29 PM
Oldvetter's Avatar
Oldvetter
You are suppose to use blue. Blue can be overcome with mechanical means (wrench), red takes heat to remove.
Old Mar 16, 2006 | 04:47 PM
vettenuts's Avatar
vettenuts
Isn't 242 the blue medium strength? All that aside, I just replaced the bolts as called for in the service manual.
Old Mar 16, 2006 | 05:07 PM
Shylor's Avatar
Shylor
Wich? Which? Witch?
Old Mar 16, 2006 | 05:50 PM
SynistrC5's Avatar
SynistrC5
oops sorry 271. Either way appearantly what i used was incorrect. However my caliper brackets are still tight .... For now
Old Mar 16, 2006 | 05:53 PM
fixvet's Avatar
fixvet
Everyone in my vette group around here used red! I used red also last month when I changed rotors and pads. I used my impact wrench to loosen them up. Turn the front wheels to get more room on the bolts. No problem with the rears either.
Old Mar 16, 2006 | 05:55 PM
VetteSiNz's Avatar
VetteSiNz
Red for the caliper bracket (large two bolts) and Blue for the two small caliper mounting bolts.
Old Mar 16, 2006 | 06:03 PM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
BLUE for caliper mount bolts!! Torque 23 ft. lbs.
Old Mar 16, 2006 | 06:53 PM
rws.1's Avatar
rws.1
Red for the Caliper brackets bolts ( two big ones) torque 125 ft-lbs
Blue for the caliper mounting bolts ( two small ones) torque 23 ft-lbs
Make sure you clean all four bolts with a wire brush prior to re-use
Old Mar 16, 2006 | 06:57 PM
bops90's Avatar
bops90
Thanks for the correction on witch which to use shylor,Must be an english teacher HUH
Old Mar 16, 2006 | 10:24 PM
Dave68's Avatar
Dave68
...just to clarify....
Red (271) is "permanent" Loctite. Typically, threads to which it had been applied can be loosened only with heat or copius amounts of torque or both.
Blue (242) is medium strength for 1/4-inch and larger screws/nuts
Pink (222) is low-strength for screws/nuts smaller than 1/4-inch.
Blue (425) is for plastic screws and nuts.
To Wich loctight
