Roadracing setup questions ...
Ok ... here we go:
1. Which brand of brake pads to use with Eradispeed rotors.
I currently have the Hawk HP Plus (Ferro-Carbon Club/AutoX) Pads and they are just about done. Is there something just as good or better that isn't so loud? The squeeking get's old quick! My rotors are almost spent as well. Should I go with slotted vs. ported next time due to cracking?
2. Coolers ... Oil and Transmission.
I don't have either and it's going to get REAL hot and soon. Do I want to stay away from the combo oil/tranny cooler like if been told?
3. Tires ...
I've heard Hoosier and Kuhmo are the better roadracing slicks offered. However, I am leaning towards the Nitto NT-01. Is this a bad choice ... has anyone run the Nitto's and the Hoosier/Kuhmo's to offer a comparison on performance and tire wear?
4. Good prefab cage/rollbar manufacturers ...
I have dreaded putting anything other than my harness bar in the car because this is my daily driver ... at least for now it is. But I've been told that I really should have something to protect me and I agree. Would a rollbar be sufficient or should I have a cage? Just in case it matters ... the track is Texas World Speedway ...
If anyone has connections on any of these items ... please, if you could, let me know. As you know ... this can get expensive quick!
Thanks in advance for your help!
Stephanie
Ok ... here we go:
Brake pads Get the C5 ZO6 pads for a great all around brake pad. Beyond that race pads ( which must be changed ) Wilwood H, PFC-01, Carbotechs, Hawk DT70s and be prepaed for LOTS OF DUST.
Dont forget the DRM Bake cooling duct extensions and DOT 4 brake fluid. the brake fluid MUST be changed before each track weekend. No excuses. Motul, Superblue and Castrol SRF are the top brake fluid braknds
Stephanie
Come on over to the General - Corvette - Autocross & Roadraceing forum. That is where all the track junkies hang out and bench race
Our company makes a ton of products to help a track car perform during race conditions. But you don't need to spend a ton of money at the begining.
Randy
www.dougrippie.com
One other item that is just coming on the market as a kit is the L.G. Motorsports combination transmission-differential cooler. This system uses the pinion gear to drive the pump and everything is mounted in the rear of the vehicle.
I am installing one on my Z06 when it comes out of storage in April.
Good luck!
I have seen the aftermath of brake failures caused by exploding cross-drilled rotors.
I have never had a problem with my slotted rotors even at TWS.
However, you are less likely to break your transmission main shaft road racing like you did at HRP drag racing. You will wear out other parts though a lot faster, springs, shocks, bushings, brakes, ....etc. One thing also. Since you have a fairly large cam in your car you need to budget in frequent spring replacements. Road racing engines spend a lot of time at high rpm which wear out the stiffer springs used on larger cams real quick. Spring breakage isn't were you want to go either. None of these racing hobbies are cheap. Just break different stuff usually.
I would pick a class you want to run in. Either SCCA T2, NCCC Division 2---etc. and see what the rules require. You will be limited in which classes you can be in due to your engine mods. Then see what equipment they require. Only get a roll cage if you have to have it for your class.
Next time at HRP just come out with some drag radials. Spinning equals not breaking transmissions and differentials. You broke last time because you dead-hooked on those M/T ET Streets. Plus if you
spin a little I just might beat you for once.
before spending a ton do the basics and run on street tires. Once you decide which direction you want to go then put together a list of things you need and start shopping around for the best deals.
You are correct it does add up quick. As for me, I never use to buy used anything because I always wanted new until I started to get into this. I now look for used stuff that I know is in good shape. I then have money left for things that are important that I would not trust being used.
remember there is a huge learning curve so take your time....
Track junkies ????? HEY I resemble that remark
Set of slotted rotors (not drilled)
Racing Brake Pads
Steel Brake Lines
Motul Brake Fluid
DRM or LGM Front Brake Ducts
1 extra Qt. of Oil
Harness Bar and Harness (provided you have sport seats)
Radiator/Oil Cooler Combo
Kevlar Boots over the Toe/Tie Ends
Stiffer Sway Bars (Vette Brakes or Hotchkiss)
If you want to take it a step further
Racing Buckets
DRM Chasis Stiffener (rear roll cage)
Tunnel Plate
Vette Brakes Extreme Suspension Set-up (springs, sway bars, sway bar links and joints, dampners) - (coil-overs are obviously the best choice for racing but unless you have a place that has scales and knows what they are doing like DRM or LGM, I wouldn't bother)
Poly-Bushing Kit
Rear/Tranny Cooler (I too am installing the LGM kit mentioned above)
Canton Accusump (for a pressurized oil system)
Six Pot Front/Four Pot Rear Brake Set-Up
I think that unless you are going to track the car very often (3-4 times a month) you will see a major improvement with the first set of changes. You should see less brake fade and keep the car a bit cooler.
Is that your C5 in the signature? Are the rear brake ducts functional. I want to tub my rear but the LPE kit gets rid of your brake ducts which I don't want to loose. Is there someone making a racing rear tub kit?
Learning and gaining experience on how to drive the car to its fullest capability in a stock configuration is way more important than brake upgrades, R compound tires or other mods. We have a female CF member out here on the left coast who can run faster than 90% of the guys (me included) driving a stock C5 Z06 with just a track alignment.
I can add this: I ran on street tires for almost a year at the track. It makes a great learning experience. They were the stock GY tires.
I got some excellent advice from one of the instructors: Make changes slowly, and get used to them. If you track your car stock in March and come back in June with R compound tires, big brakes, intake/exhaust job and a track alignment, you will be driving a different car and will have to learn all over again. Slow in/fast out isn't just about turning corners.
The changes I'm making to the car are designed to allow me to run in Texas, all year. That means steel braided brake lines and DOT 4 fluid, a harness bar and a radiator/oil cooler. I run relatively mild Carbotech pads, and have just moved on to wider slicker tires. I'm trying to lose weight, as that's some of the cheapest horsepower you can make. That's it.
Good maintenance routines will keep the car running. Spend money on seat time, would be my last bit of opinion. See you out there, and keep it smooth.
--Yak
I have an 88 C4 that we have road raced for about 4 years now in a production class and we use Kumho Victoracer 315-35x17 on the gm grandsport 17x11's on all corners. This car sees about 8-10 race weekends per year with two drivers.
We use about two sets per season and think they are great.
we use Performance Friction Pads front and rear are no brake issues on a small track. (SCCBC.NET).
Now I need to start reading about all this C5 stuff as the two cars are totally different as you all know.
As for the seat and harness ... I have a Corbeau seat, crossbar and 5pt (not 6). BTW ... where does the 6th come into the deal?
Next ...
Next ...
Next ...
[QUOTE=Wicked Weasel] remember there is a huge learning curve so take your time....[/QOUTE]
GOD HELP ME!Next ...
Racing Brake Pads
Steel Brake Lines
Motul Brake Fluid
1 extra Qt. of Oil
Racing Buckets
Tunnel Plate
Poly-Bushing Kit
Race pads
Getting rid of the Eradispeed rotors
Valvoline SynPower Fliud ... is this not a good idea?
CrossBar with 5pt/Corbeau seat
T1 Bars
Billstein Shocks
... looks like I have some checks to write. DAMN!
Thanks for the list ... I will print it out and save it.
Next ...
Next ...
Thanks again to everyone who took the time to post all this awesome information. I will continue to check the thread and not get discouraged. If any of the Texas members plan on going to TWS, MSR or HRP ... please PM me to let me know. If by chance you see a 5'4" girl in a silver Z at any of the tracks it may be me. Please come and introduce yourself. I'd love to meet you guys.
I have the Hawk D731 pads ... which of the ones you recommended give you the most bang for the buck?
If your going to make it a dedicated race car then need to check the rules of the orgainzation you want to race with. SCCA T1 is almost stock with supenssion and saftey equimpent.
If you have a 5-ppoint belt on Sparco seats your fine. The 6-points two sub belts are just that 2 sub belts instead of one.
[quote]I've done 5 track days and am now ready to take it to the next level ... that's why I've come to you guys. I am hooked ... and BADLY! I would sleep at the track if I could. I know that I can improve greatly ... and I'm ready to get to work. Is there anyway I can move this thread to the section you recommended? I must say ... I have received a wealth of information were it sits ... thanks guys!
Next ...
( Lost in Space Robot immitation)
WARRNING
- WARRNING
Guys like FAST WOMEN . . .
On the track that is.
Go get um Steph
