Pushrod question
Old Mar 23, 2006 | 02:03 AM
mini's Avatar
mini
Default Pushrod question
2002 Z06 with a G5x3 cam and Comp 921 valve spring kit, stock heads and stock rockers. I bought the 7.400" hardened pushrods from Texas Speed. Are these the correct size for my engine? Or do I need longer or shorter? Any feedback is greatly apprericated.
Old Mar 23, 2006 | 06:25 AM
DoubleZ06's Avatar
DoubleZ06
7.4" is the correct size.
Old Mar 23, 2006 | 09:38 AM
ArKay99's Avatar
ArKay99
7.4" MAY be the correct size, but...
The G5X3 is a much bigger cam than the stock cam with a corresponding smaller base circle. With stock heads and head gasket the distance betweem the lobe heel and rocker cup will be greater. I would call LGM and ask them what they recommend. They've done alot of these conversions and they could recommend the correct pushrod length with one eye closed.
Old Mar 23, 2006 | 09:41 AM
Casem1's Avatar
Casem1
You will be able to tell for sure when you install the rockers. Tighten a rocker to zero lash and then count the turns to 22 lb ft. You want to have 1/2 - 3/4 turns. If not than you need a different length. A pushrod length checker is only $20 from most vendors and using one is the only way you will know for sure what length you need. Make sure the lifter is on the base circle of the cam when you do the check.
Old Mar 23, 2006 | 08:43 PM
vettenuts's Avatar
vettenuts
I tend to think you might be short, but I would recommend a PR checker as well. It is easy to do and then you can be sure. LG should also know.
Old Mar 24, 2006 | 08:34 AM
Shane_S's Avatar
Shane_S
LG told me stock legnth. (7.4") So that's what i got and thats what i installed. seems to work fine for me. Different legnth might be needed for milled or aftermarket heads of course.
Shane
Old Mar 24, 2006 | 10:52 AM
mini's Avatar
mini
Talked to them yesterday. They told me stock length. So I got the right ones. Thanks everyone.
Old Mar 24, 2006 | 11:19 AM
Casem1's Avatar
Casem1
They probably are fine, but you should still check the number of turns from zero lash to 22 lb ft just to be absolutely sure. It is good practice to triple check everything when it comes to your valvetrain, then triple check it again. IMO
Old Mar 24, 2006 | 01:11 PM
NeverT00Fast's Avatar
NeverT00Fast
7.400 will work, go with 7.425 if you want less valvetrain noise. I'm running a bigger cam than the G5X3 and using the 7.4s with no problems.
Old Mar 24, 2006 | 01:48 PM
CraZee ZO6's Avatar
CraZee ZO6
How come some people run the 7.425 size?
Theres a thread over at ls1tech with people saying that the 7.400 cause valvetrain noise with bigger cams but when you upgrade it to 7.425's it makes it much quieter.
So whats the deal?
To Pushrod question
