Courtesy lights
Old Mar 25, 2006 | 08:59 PM
TmillerC5's Avatar
TmillerC5
St. Jude Donor '08
Default Courtesy lights are out
The lights in the footwells, rear hatch, and mirror lights seem to be out when opening the door. I have checked fuse #2 and the micro relay and they both seem ok. Any other suggestions?
Don't have your son in law screw with your car and you won't have this problem.
Thanks for any help.
Tim
Old Mar 26, 2006 | 06:57 AM
TmillerC5's Avatar
TmillerC5
St. Jude Donor '08
I need a little help from my freinds!!!!!!
Old Mar 26, 2006 | 07:36 AM
cliff_ford's Avatar
cliff_ford
He might have turned them off by quickley turning the headlamps or the courtesy lamps on and off.
Old Mar 26, 2006 | 08:42 AM
dpd's Avatar
dpd
Tim
i'm assuming they worked before he messed with the car.what did he do and we will go from there.the fuse to loo at should say "intrmonitor" or something like that.
Old Mar 26, 2006 | 08:50 AM
DeeGee's Avatar
DeeGee
Tim
Theres a fuse on the footwell panel that controls those lights. I was working down there yesterday and ended up with a little trial and error testing pulling individual fuses. Its one of the 10A ones.
Old Mar 26, 2006 | 09:22 AM
TmillerC5's Avatar
TmillerC5
St. Jude Donor '08
I was working on some interior pieces and pulled out the panel under the pass. side glove box. Got the light out and went inside for something, came back out and he said he was trying to get the light out and it sparked and now they don't work.
Thanks for the help so far.
Old Mar 26, 2006 | 10:00 AM
dpd's Avatar
dpd
fuse 29[i think it says c/laldl] is blown.it works the lamps you are talking about. suggestion: keep your son-n-law away from the car[no disrespect intended].it's in the floor fusebox
Old Mar 26, 2006 | 10:21 AM
TmillerC5's Avatar
TmillerC5
St. Jude Donor '08
I owe you a six pack. That's the one. Pulled it and burnt right thru. Maybe my Son-in-law owes you the six pack.
Thanks a million
Tim
Old Mar 26, 2006 | 10:36 AM
dpd's Avatar
dpd
Thanks a million
Tim
don't worry about it.
To Courtesy lights
