DIC code interpretation??
Old Mar 26, 2006 | 11:56 AM
TOPGUN9's Avatar
TOPGUN9
Default DIC code interpretation??
I'm getting the code C1243, which says BPMV pump motor stalled. What is BPMV?
Old Mar 26, 2006 | 02:06 PM
Patches's Avatar
Patches
Brake Pressure Modulator Valve
DTC C1242 or C1243
Circuit Description
The system relay is energized when the ignition is ON. The system relay supplies voltage to the solenoid valves and the pump motor. This voltage is referred to as the system voltage.
The electronic brake control module (EBCM) controls each solenoid valve by grounding the solenoid.
The EBCM controls the pump motor by grounding the control circuit. The pump serves 2 purposes:
Transfers brake fluid from the brake calipers to the master cylinder reservoir during pressure decrease events.
Transfers brake fluid from the master cylinder reservoir to the brake calipers during pressure increase events.
Conditions for Running the DTC
C1242
The system voltage is greater than 8.0 volts.
The system relay is ON.
The pump motor is commanded OFF.
C1243
The pump motor is ON for at least 0.3 seconds.
Conditions for Setting the DTC
C1242
The voltage across the pump motor is between 1.7 - 10.2 volts for 2 seconds.
C1243
The pump motor is stalled or turning slowly.
Action Taken When the DTC Sets
If equipped, the following actions occur:
The EBCM disables the ABS/TCS/VSES for the duration of the ignition cycle.
The DRP does not function optimally.
The ABS indicator turns ON.
The Traction Control and Active Handling indicator turns ON.
The DIC displays the following messages:
Service ABS
Service Traction System
Service Active Handling
Conditions for Clearing the DTC
The condition for the DTC is no longer present and the DTC is cleared with a scan tool.
The EBCM automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.
Diagnostic Aids
The pump motor is integral to the BPMV. The pump motor is not serviceable.
Old Mar 26, 2006 | 08:10 PM
TOPGUN9's Avatar
TOPGUN9
Thanks.
To DIC code interpretation??
