Consider that conventional oils can begin breaking down at 180 and loose their lubricating ability. Granted the M1 oil is a better oil and will take high temps. But also consider the $$ invested in Oil coolers and not oil heaters. Given oil temps of 180 or 190 with M1 I would say drive on and don't worry about it. At 180 oil will still flash off the water. Heat water in a pan to 180 and watch it rapidly disappear. I would not worry about the cooler oil. But then that's must my $.02
PS I did have oil coolers on my Pratt & Whitney turbos.. and I did fly.
Well that is the question !!!!! After all I wasn't having ANY cooling issues with oil,tranny or coolant during normal usage. But the last visit to the track...losts of high RPM, holding in 2nd gear (A4) and tight road course (Button Willow) put ALL my fluids at or past the max.....
So now with the big cooler, internal EOC I am running about 10 degrees cooler on the oil and coolant. My tranny temps have droped a lot too since the internal TOC keeps temps down before going to my external tranny cooler. The biggest difference is when I drive the car hard the temps don't jump up but rather barely increase!!!
Thanks again to everyone who posted their advise. The oil is getting up to 194-198 during my freeway comutes (30-60) minutes twice a day. And usually on the last few mile home I run it a little and get the oil to 202. On the weekend its always going to get over 200
I think a small fan setting adjustment may do the trick but I will wait to see what happens at the track first.
DH
I'm going to use mine as my DD this summer, because the kids...well, you know.
My commute is only 5 miles, so on the weekends I'll go on longer runs to get everything up to temp. I have a 160 stat and tuned fan switch points, so it will be interesting to watch the oil temps this summer.
