Red top poo poo'd? Help
Old Mar 28, 2006 | 05:34 PM
NoOne's Avatar
NoOne
Default Red top poo poo'd? Help
I went to start my C5 for the spring 2 weeks ago and nothing.
Figured no big deal. I put it on the charger, nothing. Even on START mode it barely ran the lights and I could not get it to crank.
Put cables on it and started right up. I only drive it about 5 minutes and let it idle to come up to temp. Shut it off and would not start again but I know that was no where near enough time.
Yesterday I jump it and go on a 45 minute drive to check things out.
Today, nothing, not even a blip from anything.
I don't really trust the battery testers, I've had one tell me I'm good and not been good.
Sound like a bad battery? It showed charging when driving but eventually settled into the normal range.
Old Mar 28, 2006 | 06:07 PM
John Nowak PE's Avatar
John Nowak PE
Sounds like a bad battery. When testing batteries, it is impaortant to test not only the "at rest" voltage, but also the load voltage. You can have a battery show close to 12 V just sitting there with a voltmeter between the two terminals, but then have the voltage drop to a few volts when you put a load on it (go to start, for example). In this case, the battery is bad; most likely form a bad cell inside of it.
Old Mar 28, 2006 | 11:20 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I had the exact same problem. Put in a new Red Top and it fires right up with no problems.
Old Mar 28, 2006 | 11:50 PM
Torqued84's Avatar
Torqued84
I'm no fan of Red Tops. Mine died within a year. Never wouldn't start, but headlights wouldn't pop up sometimes, radio would show wierd stuff under load, ABS DIC codes, lights would REALLY dim when applying brakes. Switched out for the old Interstate, all problems solved.
Old Jun 2, 2006 | 02:26 PM
b.j.prescott's Avatar
b.j.prescott
You guys are skeerng me....thats it Im going to give it to my S-10,it gets all my vette rejets.
Old Jun 2, 2006 | 05:31 PM
davisce's Avatar
davisce
Dude,
Just get a "Red Top" and drive on. I've had two. Yeah, my first "Red Top" died, but with a 10 year warranty who cares. I took it back they gave me a new one (no charge). . . problem solved. And they don't leak. .
Cecil
German-American Corvette Club
Baden-Wurttemberg
Heidelberg, Germany
Hometown: Ft. Lauderdale, Florida
Old Jun 2, 2006 | 05:48 PM
97C5torch's Avatar
97C5torch
Ive killed 3 red tops from my 300zx sitting for a few weeks. The gel cell batteries do not lend themselves to sitting since a slow discharge will kill em. Replace and move on.
Originally Posted by davisce
Dude,
Cecil
Baden-Wurttemberg
Heidelberg, Germany
Old Jun 2, 2006 | 05:53 PM
Mike Mercury's Avatar
Mike Mercury
I don't believe that Optimas are true gel cells. But nonetheless; there have been no similar problems reported for the Exide Orbital... which is the same exact technology as the Optima.
It may be an Optima only problem... and not a spiral wound design problem.
Old Jun 2, 2006 | 09:57 PM
GrayC5's Avatar
GrayC5
Originally Posted by Mike Mercury
I don't believe that Optimas are true gel cells....(snip)....
I believe Mike is correct.
I often see the Optima Red Top and Yellow Top and now the Exide Select Orbital® and Exide Select Orbital® XCD batteries referred to here on the Forum as gel cell batteries. However, according to their respective web sites they are all Absorbent Glass Mat (AGM) batteries and there is a difference:
"All you ever wanted to know about AGM and Gel Cell batteries"
I too have not seen people experiencing any problems with the Exide Select Orbital series of batteries like those that are being reported here with the Optimas, especially the Red Top.
Old Jun 3, 2006 | 08:42 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Another Optima battery "bites the dust." This is almost a daily happening w/ forum members using these crappy batteries. What is so unbelieveable is Corvette owners STILL buy these things knowing they are prone to premature failure. I wouldn't have one if ya gave it to me for free.
Old Jun 3, 2006 | 09:49 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Man, Im hearing about more and more of these $100.00 + batteries pooping out. I still have my Y2K OEM battery, and I think Ill replace it with a walmart or costco
Old Jun 3, 2006 | 10:22 AM
RED99's Avatar
RED99
Sounds like with the Red Tops, you just need to keep it on a smart charger when it's parked, and the problems would go away.
I just replaced my perfectly good working OEM batter from my 99 last year because of it's age, and just went with another GM Delco battery. Even though I know it has had a history of leakage problems, I am just hoping that the new battiers don't do that anymore. Also the leakage could be from over-tightening the post, or the batter moving around. I think if this one ever leaks, then I will just go to a Top Post battery.
Old Jun 3, 2006 | 10:49 AM
Mike Mercury
I hear ya... and wonder the same thing.
Old Sep 2, 2006 | 12:28 PM
JOEDEWZ's Avatar
JOEDEWZ
Default optima batteries
Never owned one either ..but you would think these guys would get the picture .I laugh when I hear guys saying well maybe you need to keep it hooked up to a tender I have been driving cars for 33years and never had to keep a charger on a car battery ,motorcycle yes. We can put a man on the moon but can't make a good motorcycle battery but that's another story...
Old Sep 2, 2006 | 12:40 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Something has definitely gone downhill in the recent past with the Optimas..........
Old Sep 2, 2006 | 08:05 PM
David426's Avatar
David426
From what I've read it looks like these Red Tops arent cracked up to what they should be
Old Sep 2, 2006 | 08:11 PM
zozmanZ06's Avatar
zozmanZ06
Default But...
But the Orbital's free replacement warranty is only 18 months.
Randy
To Red top poo poo'd? Help
Old Sep 2, 2006 | 08:57 PM
Greg_E's Avatar
Greg_E
I've had a yellow top, for about three years now, with no problems. I went with that instead of the red top, because my car sometimes sits for an extended period of time, without a battery maintainer connected. This spring I ran the battery down to almost nothing (my fault) and it charged back up and has been fine ever since. I'm just curious to know if the problems are specific to the red tops, or have people had problems with the yellow tops as well.
Old Sep 3, 2006 | 08:50 PM
ROJ#79's Avatar
ROJ#79
I've had a Red Top in mine for 2 years after my OEM died.
No problems here.
Just a note: The alternators in new cars are not made to fully recharge a dead battery, they are just suposed to keep them charged.
A fully discharged battery should always be recharged with a battery charger before using.
I believe that the guys having all the trouble either have a parasite draw on the battery or you are getting ones that have set on the shelf for a long time in the stores that don't sell many or rotate there stock.
Mine came from a distributor and I knew it was fresh. I do keep a float charger on it in the winter months when I go to FL.
Old Sep 5, 2006 | 01:16 AM
striper's Avatar
striper
I've been using the same Optima red top now for about seven years with no problems and I don't use a tender on it even if sits for a couple of weeks. The new Optimas now come with a 3-year free replacement and 84 month pro-rate warranty.
