Safe oil Temp for full throttle?????
Old Mar 29, 2006 | 10:06 AM
dbvettez06's Avatar
dbvettez06
Default Safe oil Temp for full throttle?????
Often wondered, what is the safe temp for hard driving, i have always thought around 175, but really don't know
Old Mar 29, 2006 | 10:40 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
I am not sure if you are asking about the safest temp to start "throttling" the motor or operating temp, so I added my 2 cents worth on both.
Safe temp to start hammering the motor is 150 F
Safe temp to operate - normal driving - 220 - 250
Safe temp to operate - hard driving - 220 - 290
Best temp would be to maintain 225 - 240 - but you may need an oil cooler to do this.
Hope that helps and these are my guidelines based on good synthetics.
Charlie
Old Mar 29, 2006 | 10:43 AM
AU N EGL's Avatar
AU N EGL
COnsistnat hard driving we see 250-260 with oil cooler.
Old Mar 29, 2006 | 11:18 AM
WKMCD's Avatar
WKMCD
Charlie
I keep my H/C motor under 2k until the oil temp reaches 150 degrees F.
Old Mar 29, 2006 | 11:25 AM
dbvettez06's Avatar
dbvettez06
Charlie
Sorry what i meant is: Start the car in the morning, as the oil wams, what is the minimum temp when you can hammer the car...170/180 ??
And, any facts on this?
Old Mar 29, 2006 | 12:51 PM
David426's Avatar
David426
You can monitor either one of the temperatures by pressing the gauges botton for your DIC Monitor your oil temp, when it gets to 150 degrees switch over to your radiator fluid temp and see what it says. This will answer your question.
Old Mar 29, 2006 | 01:42 PM
dbvettez06's Avatar
dbvettez06
I am aware of the DIC and all functions...What TEMP is safe to beat on the car????
Old Mar 29, 2006 | 01:50 PM
triblk6spd's Avatar
triblk6spd
you need to read the thread.
Old Mar 29, 2006 | 02:20 PM
David426's Avatar
David426
I don't think he gets it. Oh well
Old Mar 29, 2006 | 06:02 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
150 DEGREES!!!!! FARENHEIGHT!!!!!
Better?
Old Mar 29, 2006 | 06:08 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Better?
Old Mar 29, 2006 | 06:12 PM
vettenuts's Avatar
vettenuts
I don't run it over 2,000 RPM until the oil is at 180 minimum. With the aftermarket springs, I would prefer to get them warmed up before cycling them too hard. I don't have any hard data on this, but it is just a rule of thumb I use with my car.
Old Mar 29, 2006 | 08:17 PM
TEXHAWK0's Avatar
TEXHAWK0
I think there have been other threads on this question before, and the consensus was at least 160 degrees.
Old Mar 29, 2006 | 08:20 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
For me the magic number is 174 degrees. Not sure why.....must be something I read around here though!
To Safe oil Temp for full throttle?????
