daytime headlight sensor
Old Mar 30, 2006 | 08:00 AM
John K Anderson's Avatar
John K Anderson
3rd Gear
Default daytime headlight sensor
is there a way to cancel the auto headlight sensor out completely, so that it is a manual function ie.pull headlight switch only when I want the lights on.Now dont get me wrong the daytime lights that are on all the time are ok. but the headlights popping up in my garage or under a brigde or when the sun goes behind a cloud is alittle to much! When itook it to GM the tech tried to cancel it out but couldnt. Ihave tried the parking brake handleup a little,Ihave tried to cover the sensor on the dash no go.if anyone out here knows if theres a fuse or something else I greatly appreciated. It is Canadian car 2002 roadser that Ihave had no other problems with,but ihave already replaced one headlight motor,cause of defect probobly unessesary over use,so you have it.Signed joni eh!
Old Mar 30, 2006 | 08:30 AM
DeeGee's Avatar
DeeGee
I'm pretty certain you can't turn off the Twilight Sentinel on a Canadian car. the Canadian Forum members will confirm that
Twilight (Optional in United States,
Standard in Canada)
Press the OPTIONS button until TWILIGHT - OFF
appears on the display, then use the RESET button to
page through the following selections:
 TWILIGHT - ON
 TWILIGHT - OFF
If you choose TWILIGHT - ON, press the OPTIONS
button again to display DELAY TIME 1 2 in the DIC.
Use the OPTIONS button to switch between delay time
1 and 2. You can increase the delay time by pressing
button 1 (1 FUEL) or decrease the time by pressing
button 2 (2 GAGES). Each bar is equal to 12 seconds.
Old Mar 30, 2006 | 03:34 PM
rbrtclk's Avatar
rbrtclk
Go to the fuse panel by the passengers feet, pull the #42 relay. Works fine.
To daytime headlight sensor
