Question about CCW wheels
Old Mar 30, 2006 | 04:21 PM
SkyWarp's Avatar
SkyWarp
Default Question about CCW wheels
I plan on getting CCW classic's. I want the 18x11.5 on the rear with 18x10 on the front. I will be running 335/30 on the back. How much do the rear stick out from the fender?? pics would be great tks
Rob
Old Mar 30, 2006 | 05:17 PM
AU N EGL's Avatar
AU N EGL
they will stick out about 3/4 " but you most likely will need 12" rims, not 11 1/2".
What tires are you looking at?? Not all 335s are the same width and can very by 1/2 in or so.
Old Mar 30, 2006 | 05:42 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
With that backspacing, you'll probably recieve a spacer for each rear wheel. I run 18 by 12's with a different offset and am tucked in. You'll stick out maybe 1/2" if that.
Old Mar 30, 2006 | 07:12 PM
Mike04's Avatar
Mike04
I believe the CCW 11.5 stick out the same as the 11", the extra .5 is on the inside. My 11" stick out just a small amount. Not all 335s will fit these rims, check with the tire maker and give CCW a call. They are great to work with. They will even sell you the tire wheel combo.
Old Mar 30, 2006 | 07:31 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I had the same setup on my car... here is a sideview.
VR
Old Mar 30, 2006 | 08:33 PM
Rag-Top Rick's Avatar
Rag-Top Rick
VR
Fyi - I have the same set-up as above but lowered a little more (aprox 1-1 1/4in.), the tire looks like it sticks out less with the fender down closer to the tire.... at least IMHO. Sorry........ I don`t have any pics!
Rick
P.S. No, no rub!
Old Mar 30, 2006 | 08:37 PM
vetterdstr's Avatar
vetterdstr
WHen I had mine slammed the tires did move inward...
VR
Old Mar 30, 2006 | 09:51 PM
402Sam's Avatar
402Sam
To run a 335 on these wheels, does the car need to be tubbed?
Old Mar 30, 2006 | 10:28 PM
vetterdstr's Avatar
vetterdstr
nope... Not with the CCW 11.5' rims. They have a special off set and fit the car fine.
Old Apr 1, 2006 | 06:48 PM
RWE 427's Avatar
RWE 427
Veteran: Marine Corps
Checkout my pics. I'm running the CCW package as well.
http://community.webshots.com/album/91545045neZmSK
Old Apr 1, 2006 | 10:48 PM
Dirty Howie's Avatar
Dirty Howie
Not sure if this helps or is relevant but I have CCW 11.5 x 18 rears with 305 R2's. Car is lowered......long bolts in the back cut front bushings.
I am getting rubbing (slight) on the inner fender well against the inside tire side wall. But I do track the car also.
DH
Old Apr 2, 2006 | 03:02 AM
vetterdstr's Avatar
vetterdstr
Rubbing on the inside at the top is ok... there is a plastic liner in there and a little rubbing doesnt hurt anything. Its not like you are coming into contact with metal or anything.
VR
Old Apr 2, 2006 | 03:42 AM
Dirty Howie
VR
Thanks buddy......I wasn't really worried
DH
Old Apr 2, 2006 | 04:22 AM
vetterdstr's Avatar
vetterdstr
DH
I knew you were cool with it... It was more of letting the person who started this thread know that fact.
Old Apr 2, 2006 | 05:48 AM
JETZ's Avatar
JETZ
$50K+ cars with the tires sticking out, very cool! I read the sixties were over.
When you hit a pothole, or curb, and the tire hits, and fractures your wheel lip you'll be re-thinking your choice.
345/25/20/13 INSIDE the well, and slammed!
Old Apr 2, 2006 | 08:37 AM
AU N EGL's Avatar
AU N EGL
Or you just get wider fenders. These rear fenders are 3/4" wider then stock.
I dont think tubbing a car is a good idea at all. Tubing makes the car have a narrower track width. Wider is better.
I use longer ARP studes and a 3/8" spacer
Rear wheels are 18x13" rim with 18x335/30 Hoosier. a 335 Hoosier is about a 340-342 on most other tires.
Old Apr 2, 2006 | 07:55 PM
Dirty Howie
Tom: I think your set up is ideal both cosmetically for performance. I have the CCW 11.5 and you have to look close to see they stick out slightly more than stock. But if I ever go to a wider wheel I would do what you did. What was the cost ???
DH
To Question about CCW wheels
