Drivers Side Door, Electrical Issues????
Old Apr 18, 2006 | 07:03 PM
jughead1's Avatar
jughead1
From: Assault is a behavior, not a device! Cypress TX
St. Jude Donor '11
What special tool do you need to pull the connectors from the DCM? I'm about to go in my door and want to check and clean all connections.
Old May 5, 2006 | 07:49 PM
Allgonoshow's Avatar
Allgonoshow
I'm glad I found this thread. I get all the error codes every time I take a right turn. The fuse for the LDCM would pop all the time so I have left it out for a while. Still get all the codes durring a turn, but now I tend to think that I have a short in there somehow. Going to pull the panel tommorow. I already checked the plug inside the A pillar. Pins and sockets all looked clean and strait.
Old May 5, 2006 | 11:49 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by viper8u2
got the same thing, still does it now.
Passenger side works. its like the actuator wore out or something, i hear a click but nothing
Mike
see this thread here:
get a new module and problem solved.
http://forums.corvetteforum.com/show....php?t=1383592
Old Jul 28, 2006 | 11:03 AM
96-speed's Avatar
96-speed
Originally Posted by rws.1
If you have an intermittient lock/unlock but can hear the click.... the relay in the door control module is bad ( arced/burned)
You can replace the module part cost (~$300) or the relay part cost ($ 1.30 +$5 shipping)
To replace the relay see CF members web site... http://www.ronjpics.com/Corvettestuff.htm#DCM
you can buy the relay at www.digikey.com
part number 255-1239-ND 10A 12VDC
Just replaced the relay for the driver's side door lock. Works great now!
Anyone know if this replacement is going to give a longer service life than the OEM one? Anyone want to guess why the OEM relays go kaput so fast? Cheap component?
Oh yeah, 2 days after I fixed the driver's side my passenger side some locking
Ryan
Old Jul 28, 2006 | 11:10 AM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Do button lights light up when the headlights are on? My module works fine, but it doesn't light up.
