corvette service intervals?
Old Apr 6, 2006 | 11:21 AM
mbella2000's Avatar
mbella2000
Default corvette service intervals?
Hi all..
Can anyone tell me the service intervals for a corvette? i have a 2000 corvette with only 29,000 on it. what and when are services supposed to be done as in trans fluid chaging, valve adjustment, timing belt, rear axel fluid ect. I dont know whats been dont to my car as I got no receipts with it, but wanted to know what GM recommends at what intervals..Thanks
Old Apr 6, 2006 | 12:17 PM
vettesmith02's Avatar
vettesmith02
Need to know a little more about how you drive the vehicle; whether it is manual or automatic, etc.
You can buy a user's manual, if you don't have one, from the Museum and it should give you the maintenance intervals...
Old Apr 7, 2006 | 12:12 AM
mbella2000's Avatar
mbella2000
Oh yea sorry.... Its an automatic..without ridecontrol. The guy I bought it from didnt give me the manual or maint records..Is there a 30k maitenance? what does it entail? Thanks
Old Apr 7, 2006 | 12:30 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
go to www.mygmlink.com and register then you can download the owner manual in PDF, it has the service intervals. You do not have a timing belt.
The computer (DIC) will tell you when to chage the oil or you change it once a year. Since you don't know when the last one was you should chage it.
Old Apr 7, 2006 | 07:47 AM
debmwb's Avatar
debmwb
Originally Posted by mbella2000
Hi all..
Keep with what GM says about fluid changes. No adjustment necessary on the valves unless aftermarket adjustable rockers have been installed. Vettes also use a timing chain, so there is no belt to replace.
To corvette service intervals?
