Help!!! Pcm : No Commn
Old Apr 8, 2006 | 08:54 AM
Aziztop's Avatar
Aziztop
2nd Gear
Default Help!!! Pcm : No Commn
I Was Programing My Freind's Corvette '99 ,When I By Mistake Pulled The Plug ,Then Everything Went Crazy ,then I Tried To Pull The Codes ,and This Message Appears (( PCM : No Commn )) .
The Programmer Was Diablo Sport
BTW The Car Wont Start , There Is No Coolant Reading And Every Warning Light Is On ,So Help Me Please ASAP
Old Apr 8, 2006 | 03:34 PM
ronnie948's Avatar
ronnie948
Cruise-In III Veteran
Default Computer needs to be reflashed at the dealer.
You will probably have to have the car flat-beded to the dealer to have the computer reflashed with the stock program. If you just take the computer out and to the dealer make sure you have your complete VIN # with you. The dealer will probably charge you $75.00 to reflash it.
Ronnie948
Old Apr 8, 2006 | 03:46 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That is NOT a good thing!! The information provided above it correct!
BC
Old Apr 8, 2006 | 03:50 PM
JR_VET's Avatar
JR_VET
Ronnie948
I hope that you get the car reflashed cheaper than that. If you have a good relationship with your local dealer. But call then and see if they will do the reflash with PCM out
Old Apr 8, 2006 | 04:59 PM
David426's Avatar
David426
I did the same exact thing with a Hyper Tech Programmer also. I freaked out. The car would barely run when I started it, then died and would not start, I was freaked out at the time. I pulled the battery cables and hooked them back up after about 20 minutes. Thank God it started. No codes, ran fine. Don't know if this will work for you, I'd try it first.
Old Apr 8, 2006 | 06:01 PM
Aziztop's Avatar
Aziztop
2nd Gear
ronnie948 Thank You Very Much
Thank You My Corvette Family
David426 Trust When I Say ((( I Tried Everything )))
To Help!!! Pcm : No Commn
