Code Reader Location:..
Old Apr 10, 2006 | 03:41 PM
kg54trains's Avatar
kg54trains
Default Code Reader Location:..
98 Coupe, Auto, Stock.
looking for the car's plug in adapter that is for a code reader. Most cars are located on the drivers side and is visible by just looking under dash. I have looked on the driver's and see no adapter to plug into.
Thanks for the Help.
Old Apr 10, 2006 | 03:42 PM
cliff_ford's Avatar
cliff_ford
Keep looking. It's under the steering column just behind the back of the facia.
Old Apr 10, 2006 | 03:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its called the ALDL PORT (Assembly Line Diagnostic Link Port) and it is located in the close out panel under the steering column. Look straight up!
Do you know that you have a built in code reader??
Check out this web site for the scoop!
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
[www.corvettedoctor.com
Bill C
Old Apr 11, 2006 | 08:35 AM
kg54trains's Avatar
kg54trains
Default Follow-up
Bill C
Thanks for information
On Board system.... trouble clearing H codes. The separate code reader does not pick up history codes so it will not also clear History codes.
I will keep trying.....
Old Apr 11, 2006 | 11:55 AM
PierEagle's Avatar
PierEagle
Do you have the procedure for bringing up the diagnostic codes on the DIC? The DIC should show your codes, with either an H (history) or C (current) behind the code. While viewing a given code, press and hold the reset button until it beeps. That should clear it.
Cheers
Old Apr 11, 2006 | 11:58 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Cheers
That link is here
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Apr 11, 2006 | 04:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill C
If you follow the above website procedures, you can just about do anything with the codes! It shows all historys, current codes and it will allow you to clear the codes! Well,,except for a current code beacuse everytime you clear it,,, it comes back. Thats why it is CURRENT!!!
Bill
To Code Reader Location:..
