Head Install - P0300 Misfire Error
Old Apr 17, 2006 | 09:27 PM
vettenuts's Avatar
vettenuts
Default Head Install - P0300 Misfire Error
Just finished installing a set of Dart 205's. Car has a VHP cam which is 216/224 .551/.551 115LSA which is not too radical but is a little lumpy on idle. Had no codes prior to the heads, but now it is throwing the P0300 and when I look at which cylinder, it is all of them not limited to just one. I can't detect a misfire and the car absolutely runs fantastic from cold start to running hard. I have not yet had it tuned from the head installation, is this a normal thing to have happen?
Old Apr 17, 2006 | 10:01 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
isnt that the misfire code? I think the threshold for P0300 can be raised so not to "hit" that code
Old Apr 17, 2006 | 10:17 PM
South Tex Vette's Avatar
South Tex Vette
By changing the heads & cam you have changed the dynamic compresion values that the PCM reads, thus the DTE misfire. I'm saying this from experience and other post that I have read.
Old Apr 17, 2006 | 10:22 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Wow..
I agree, that cam doesn't look that radical at all.
I'm sure you know that the PCM is sampling the crank sensor, measuring the time between each sensor pulse to determine engine mis-fire.
If it is loping as you suggest, then that might be enough to trigger it. I'll add if the mixture is fairly lean it may increase severity of the lope.
Old Apr 17, 2006 | 10:30 PM
vettenuts's Avatar
vettenuts
Cam was in before the heads, but the static compression is up due to the smaller chamber on the Dart heads. Would that cause it?
Old Apr 17, 2006 | 11:03 PM
Dan_the_C5_Man
I don't have any pratical experience to share, other than understanding how the mis-fire detection operates. (BTW, manufactures struggled to develop mis-fire detection, causing a delay in releasing OBDII-compliant cars).
All it can do is sample the duration between crank sensor pulses; it has no knowledge of static or dynamic compression ratios, VE changes, etc.
So if it's loping as you say (and knowing you you've already checked the plugs, wires, manifold sealing, etc.), then I guess you'll need to edit the PCM to adjust / prevent triggering the code.
Old Apr 18, 2006 | 08:06 AM
vettenuts's Avatar
vettenuts
Just went over everything again, can't find anything wrong. Only thing I can come up with is the new compression ratio has changed the dynamics slightly or I am running last years gas since the car just came out of storage.
Old Apr 18, 2006 | 09:15 AM
SpeedyZ's Avatar
SpeedyZ
My car is not on the road yet so it is not tuned yet, but after installing a much more radical cam than yours it will set the P0300 code when started cold. Not because of rough idle but surging. When hot it never sets the code and has a pretty rough idle. But cold it starts to surge like the idle control is just a tad behind and it causes the engine to surge up and down about 400 RPM then it will trip the P0300 code. Does yours set the code after the engine has run for 5 minutes or more? Have you had it tuned yet? If not tuning will probably fix that code.
Old Apr 18, 2006 | 09:55 AM
vettenuts's Avatar
vettenuts
Not tuned yet, my tuner is telling me something is wrong. I have gone over everything and can't a single thing wrong. My idle doesn't hunt too much at all.
Old Apr 18, 2006 | 10:06 AM
ArKay99's Avatar
ArKay99
Curious, I am having a similar problem, and running too rich on one bank and too lean on another caused by misfiring. I've done all the obvious as you have. Now I'm swapping coil packs, etc. Do you have tools to log your idle? Also, I'm wondering what your idle speed and timing are set to.
Old Apr 18, 2006 | 12:13 PM
vettenuts's Avatar
vettenuts
My idle is set to stock, around 750-800 from what I can tell.
I did an idle relearn on it, including turning on the A/C and haven't had the code come up since. Not sure if the PCM just needed some learn time or what. Knock on wood, hopefully that was it.
As for you rich one bank, lean on the other. Someone just went through this and the O2's were crossed from where they should be. Have you done anything with the O2's recently?
Also, valve springs?
Old Apr 18, 2006 | 04:05 PM
ArKay99's Avatar
ArKay99
Unfortunately, the O2's are not reversed. I was under there this weekend and replaced the 2 fronts due to them getting lazy from running so rich. It didn't fix the problem so my LTFT's are still way off at idle.
It's not a valve spring either. I checked them out, they only have about 3500 miles on them and still look fine, no breaks.
Old Apr 18, 2006 | 04:27 PM
vettenuts's Avatar
vettenuts
Awful strange one bank is doing it.
Old Apr 18, 2006 | 04:53 PM
ArKay99's Avatar
ArKay99
I know. I hate that.
Old Apr 18, 2006 | 05:26 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Maybe you should just take it to the tuner and have him check it out on the tuning equipment, maybe he can further determine what this is from? Sounds like you are playing a guessing game that may never end.
I could be wrong, but I would call him back up and ask if he is willing to try that.
Micah
Old Apr 18, 2006 | 10:34 PM
South Tex Vette
When I installed my GX3 the idle surging was an on going problem that my tuner finally figured out how to fix along with the constant misfire code. I have had over a 100 different variations of tunes flashed to get it right. My tuner uses HP Tuners, and the most benificial thing we do is record all of runs at the track and some on the road, which allows you to further tune to perfection. If you are using HP Tuners you can call him.
Ruben
Sanoli's Performance
(956) 424-0600
My C5 has been their guiny pig for three years now. 11.39 @ 121 NA on drag radials on stock bottom end. Of course every different component changes the varitions in the tune.
Old Apr 19, 2006 | 11:32 AM
Boob's Avatar
Boob
If you get it tuned they should be able to take care of that problem. At least....my tuner did. And I had the exact same problem.......it drove me nuts because I checked and rechecked.
Go get it dyno tuned by someone who has a lot of experience with C5's and your problem will be history.
To Head Install - P0300 Misfire Error
Old Apr 19, 2006 | 11:50 AM
vettenuts's Avatar
vettenuts
Re-checked this morning, sure enough cold start the P0300 came up in Autotap. Sure hope its only a tuning issue.
Old Apr 19, 2006 | 01:31 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
All new modded head and cam car will get that code from time to time. I do not reset mine, but after so many starts it resets itself.
Old Apr 19, 2006 | 06:32 PM
vettenuts's Avatar
vettenuts
Yep, three hot starts later and a check with Autotap, no error in memory. I think its a tuning issue and hopefully I will be on the dyno by the end of the week
