Problem Getting old Headers off !
Apr 20, 2006 | 11:32 AM
Hey guys I am installing my new headers today and have every bolt out of the stock manifold so its ready to come out but I can't seem to be able to pull it off the head. I have tried prying between the header tubes as to not touch the head and it won't dislodge.
Any opinions or Ideas?
thanks
Apr 20, 2006 | 11:51 AM
CI 6-7-8 Veteran
St. Jude's Donor '06-'10-'11, '15
You either missed a bolt or didn't disconnect the bottom collectors.
Apr 20, 2006 | 12:21 PM
Quote:
Apr 20, 2006 | 12:53 PM
Cruise-In VIII Veteran
St. Jude Donor '07
Apr 20, 2006 | 12:55 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There bolted together at the bottom of the bell housing and will need to be un bolted there to get them to seperate.
BC
Apr 20, 2006 | 04:05 PM
Remove your H-pipe first, this is the center section of exhaust between the manifolds and the cat back. But put a bolt back in each manifold first or they will fall and hit you in the head when you remove your H-pipe!
If you by chance have the H-pipe off, then you have missed a bolt or two. Those factory manifolds are so heavy there is no way they will stick to the engine. Should be 6 bolts in each manifold.
Apr 20, 2006 | 04:48 PM
I'm retarded ! I was missing the lower bolt on the bottom of the air tube. Still new to this corvette thing
thanks a bunch !
Rookie out
Apr 20, 2006 | 05:29 PM
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
Quote:
thanks a bunch !
Rookie out
Good catch. I was just about to mention to ya. Took me a while to figure out when I did mine.
Apr 21, 2006 | 07:30 AM
St. Jude Donor '07
Quote:
Yeah, me too.
