Question On Diff Leak?
Old Apr 20, 2006 | 12:42 PM
Benchpress's Avatar
Benchpress
Default Question On Diff Leak?
I did a search but didn't get much info. Has anyone changed the gaskests on the getrag. Mine has started leaking on the right side. Any special tools needed besides a 10mm socket to remove the cover plate after shaft is removed.
Old Apr 20, 2006 | 12:50 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Maybe it's me, but I would just pay someone to do it than hassel with that. Hope someone chimes in and gives you some decent tips.
Micah
Old Apr 20, 2006 | 03:35 PM
JSTAN's Avatar
JSTAN
You will need a 10 mm hex drive to remove the diff fluid bolt. I would also recommend using some silicone sealer on the cover. Just for some added resistance against any future leaks. I just did this to mine (2nd time around), hopefully this will fix the leak.
Old Apr 20, 2006 | 04:21 PM
Benchpress's Avatar
Benchpress
Did yours leak on the right side as well? I seen that most seem to leak on the left side. The seal itself is not leaking, but I bought a new one to change out at the sametime.
Old Apr 20, 2006 | 05:24 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Is yours leaking from the main side cover or the output shaft seals?
Old Apr 20, 2006 | 05:47 PM
Benchpress's Avatar
Benchpress
Main side cover!
Old Apr 20, 2006 | 05:59 PM
SpeedyZ's Avatar
SpeedyZ
GM now recommends to replace the side cover O-rings and use RTV sealer on the cover flanges. I would replace the side axle seals while you in there. You should be able to do it all without dropping anything out from under the car. Hardest part will be removing the drive axle.
Old Apr 20, 2006 | 06:07 PM
Cajundude's Avatar
Cajundude
Nah, that's easy. Just follow these directions. I think you can get to the side cover without dropping the x-member, but you will probably have to remove the cat back.
Old Apr 20, 2006 | 06:13 PM
Benchpress's Avatar
Benchpress
Thanks for the info Guys.
Old Apr 21, 2006 | 04:20 PM
SpeedyZ's Avatar
SpeedyZ
Nah, that's easy.
I didn't say it was not easy, I said it was the hardest part. Covers will come off OK with the cat back off.
To Question On Diff Leak?
