Smooth Air Coupler Installation
Old Apr 20, 2006 | 10:34 PM
Dave Fontanini's Avatar
Dave Fontanini
Default Smooth Air Coupler Installation
I recently purchased one of the smooth Couplers to replace the accordian type stock air coupler. It is so stiff, I couldn't get it on the throttle body or the air bridge.
This coupler looks like a big piece of radiator hose and it is tappered
Does anyone have any tips? I tried putting a little dab of soap on it to make it slide better, but it almost seems it is to small.
I have 2003 C5 Coupe
Thanks in advance for any replys:
crazy:
Old Apr 21, 2006 | 06:12 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I would suggest soaking it in a pan of hot water for a few minutes, to soften it up. Then, maybe just rub a little motor oil on the ends, to allow it to slip over the connections.
Old Apr 21, 2006 | 10:56 AM
Spark 2's Avatar
Spark 2
St. Jude Donor '07-'08-'09
You can put your hand inside the coupler to start it on the throttle body, and then use two small (pocket) screwdrivers to gently start it on the air duct.
Good luck!
Old Apr 21, 2006 | 12:01 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Spraying the ends (inside and outside) w/ silicon will help greatly. Napa sells it.
Old Apr 21, 2006 | 12:30 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
I wonder what you have. If it looks like a radiator hose I would consider returning it.
What I would use is a silicone coupler, not rubber. The outside surface should be shiney with about a 1/8" wall thkns. It should swage down about mid-length to match the outside diam of the TB.
Eklers, Mid America and lots of other suppliers carry them, about $50.
Hope this helps. Good Luck.
Old Apr 21, 2006 | 02:46 PM
Cajundude's Avatar
Cajundude
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Spray it with some WD40.
Old Apr 21, 2006 | 03:07 PM
Tigershark3's Avatar
Tigershark3
I got one of these from MA - looked out of place and tacky. I sent it back and put the stock one back on. I doubt if it did anything anyhow. My $.02
Old Apr 21, 2006 | 03:16 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
http://siliconeintakes.com/
The same part cost me $17
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Apr 21, 2006 | 03:20 PM
01vetteC5's Avatar
01vetteC5
i got one of them it fit pretty easy just a bit if twisting and what not i donno if it dose much but ohh well i use it to hold me intake in place (aftermarket) lol
Old Apr 21, 2006 | 03:33 PM
ThePizzaC5's Avatar
ThePizzaC5
Thanks!!!! I KNEW there was a place that'd sell them for less than $30+.
Anyone have any insight to what size reducer I need for a stock '00 MAF to TB?
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Lube that sucker!
Seriously, a little twisting and pushing it should slide on.
Old Apr 21, 2006 | 03:44 PM
JPEAK's Avatar
JPEAK
Not to start a coupler bashing but, is it for cosmetics or is there performance gain? If performance gain, then why is the new Z06 still have the ribbed style. Seems the Z06 could have boasted with more HP.
Old Apr 21, 2006 | 04:08 PM
ThePizzaC5's Avatar
ThePizzaC5
GM probably just stuck to the good old reliable accordion merely for the reason that it's something they know won't fail. They put a new part on, and who knows.
I've read there's a small performance gain with the coupler. It's also nice having a new part to install.
Old Apr 21, 2006 | 04:35 PM
dudleyd's Avatar
dudleyd
4" to 3.75"
Old Apr 21, 2006 | 04:38 PM
ThePizzaC5's Avatar
ThePizzaC5
Thanks -been sitting here waiting for a response so I could order one..
Old Apr 21, 2006 | 05:10 PM
dudleyd's Avatar
dudleyd
These couplers (siliconeintakes) wont work if you are using the stock airbridge. The TB is 4" as is the MAF but the stock airbridge is a oval shape, aprox. 4" x 4.75" ??? at least at the TB side as I remember. The 4" to 3.75" coupler works with after market airbridges like the carbon fiber power duct by BPP.
To Smooth Air Coupler Installation
