Cam Sensor
Old Apr 20, 2006 | 11:09 PM
griffgoody's Avatar
griffgoody
Default Cam Sensor
Has anyone ever had to change their cam sensor. I have a 98 auto vert that what crank half the times. It will spin the motor over put want fire up. Every now and than i can drive the car a day or two when it will crank with no problems. But its been 5 days without cranking and now its finally giving a code of the cam sensor. Could this be the problem. PLZ HELP TKS JOHN
Old Apr 21, 2006 | 07:25 AM
vettenuts's Avatar
vettenuts
The car will start with a bad cam sensor if I remember correctly. You have to remove the intake to get at it, once off it shouldn't be too bad to replace.
