Tire Pressure re-learn problem
Anyone have some other tips?
The one on the RIGHT or the one on the LEFT??
This is a late model C5 sensor 2001-2004
The one on the right is early C5 sensor 97-2000. It is larger and flatter.
BC
BC
Here is the link to the Tire Pressure Sensor sequence:
https://www.corvetteforum.com/techti...D=77&TopicID=1
If you cant get to it:
Submitter's Name: Chris Palfi
Email Address: Private
Corvetteforum.com Member Alias: Brazen C5
I used this message forwarded from a fellow forum memeber and it worked just as described. Thought I would post for anyone else that may need to reset their TPMs. 1) Turn ignition on 2) Press "Reset" button in order to clear any IPC display warning messages 3) Press and release the "Options" button on the DIC to scroll through the display options until the IPC display is blank 4) Press and hold the DIC "Reset" button for 3 seconds 5) Press the "Options" button again until TIRE TRAINING message appears 6) Press "Reset" button until the IPC "Learn L Front Tire" message appears in order to begin the programming 7) Install the J41760 Tire Pressure Monitor (TPM) System Programming Tool (large magnet will do) over the left front valve stem 8) The horn will sound, indicating the left front TPM sensor is programmed (if this takes more than 15 seconds, pull magnet back and try again, it will give you three tries. Then you must start over) 9) When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages: -Learn R Front Tire -Learn R Rear Tire -Learn L Rear Tire Programming can be canceled by turning ignition off, waiting 2 minutes with no sensors being learned, finishing all 4 wheels or through the DIC. If the programming is canceled with less than 4 sensors learned, it will only accept the codes programmed up to that point.
KBase v1.0
©2001 TLC Web Enterprises
All Rights Reserved
Timer: This page was generated in
0.503 seconds.
If there strapped in,, you need to figure out where they are exactly so that you can hold the magnet over them!
Bill
Kevin
