Cam install how too?
Old May 2, 2006 | 10:33 PM
killaz's Avatar
killaz
Default Cam install how too?
I saw a websight with a cam install how to for a c5 vette but can not find it. Anyone have one? Or a link?
Old May 2, 2006 | 10:39 PM
mowton's Avatar
mowton
www.ls1howto.com
Old May 2, 2006 | 11:46 PM
bdiddo's Avatar
bdiddo
That site provides a good step by step, however, you will find the install much more straight forward by removing the heads. I just completed mine and simply did not have adequate clearance to remove the cam. Of course you will run into the additional cost of gaskets.
Old May 3, 2006 | 12:56 AM
killaz's Avatar
killaz
The heads have to be removed? What makes it easer? I was thinking i would replace my ls1 intake with an ls6, and my heads would be able to stay on the car.?
Old May 3, 2006 | 06:20 AM
vettenuts's Avatar
vettenuts
Heads don't have to come off. I did mine alone, not even help with the A/C condenser. I took the LS1howto instructions and modified them for my own use since I wasn't doing heads and I was doing a Crane valve train.
Old May 3, 2006 | 12:34 PM
VetteNoob's Avatar
VetteNoob
The only thing I found to make my life easier was removing the hood. That allowed me easier access to the front of the car without having to reach from the sides.
Just ignore the head removal and install directions on LS1tech and you'll be fine. Just remember to be careful and keep the lifters up or you will be buying head gaskets :P
Old May 3, 2006 | 02:53 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Just did a swap on a ZO6 a week ago and didn't even remove the intake, much less the heads.
Old May 3, 2006 | 02:56 PM
Casem1's Avatar
Casem1
And maybe dropping your oil pan.
Someone here knows the diameter of wooden dowel that will work to hold the lifters, but I would double up with some pen magnets as well. I would think that combo would hold the lifters indefinitely. Heck, half of my lifters were held in the plastic trays alone when I removed them...
Old May 3, 2006 | 06:57 PM
78Vette-SA's Avatar
78Vette-SA
Remove valve covers and loosen (but no need to remove, rockers.
You need to remove the fan (easier from below) and the Rad, but not the A/C Condensor. All the obvious rest of the junk has to come out (Rack, Balancer, etc.)
While rotating the cam in place by hand (screw a waterpump bolt in for a handle), slide a 5/16" wooden dowel into the holes just above the cam on both sides. You will have to give it a little push here and there but it will go. This will hold the lifters up with no worries.
Then pull the cam out (remove the waterpump bolt once you get your hand around it) and rotate it while gently pulling it out. It will go right up to the A/C condenser. Angle it down at this point and she'll pop right out.
Reverse and blast-off. Don't forget to tight the @#$% out of the Harmonic Balancer bolt and use a new one.
ps: Don't go to much on the lift if you are using stock springs. I don't know the limit but I don't install a cam over .588 lift without changing the springs. Maybe not needed, but I prefer to. Springs can also be done without removing the heads.
Old May 3, 2006 | 10:24 PM
402Sam's Avatar
402Sam
I just used pen magnets down the pushrod holes to hold the lifters up. If you never did this I would recomend having someone there that has. If you drop a lifter into the oil pan you will have a whole new world of issues to deal with.
To Cam install how too?
