holy **** another problem
Old May 3, 2006 | 09:57 AM
c5vette_dallas's Avatar
c5vette_dallas
Default holy **** another problem
if my car is off long enough..the avg. mile per gallon will reset and so will my clock...i havent noticed anything else yet..any input fellas?
Old May 3, 2006 | 10:53 AM
ALLEGRO's Avatar
ALLEGRO
Have battery load-tested. If that's OK then I suspect a ground issue
Old May 3, 2006 | 11:05 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You most likely have a battery that has insufficient cold cranking voltage! You probably saying "What the hell is that guy talking about??? My car starts just fine!!!
If you look at your DTC codes in the DIC, you will most likely see a ton of "U" series codes indicating that those modules saw insufficient voltage at some period of time. Your BCM and Instrument panel will be two of them. That is where the memory is stored. When the module shuts off under low voltage, it looses its memory.
Get a new battery and that should solve your problem. If it doesn't, let us know and we will give you a couple of other things to check.
Bill Curlee
Old May 3, 2006 | 05:31 PM
c5vette_dallas
yes..i am getting 3 U codes...loss of communication with a few things...cant think off top of the head...but that sounds like the problem
Old May 13, 2006 | 03:09 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
So,,,,,did you get the battery checked out?? Any up-date on the problem??
BC
Old May 13, 2006 | 05:34 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
BC
with Curlee.
Most likely a battery problem.
Old May 13, 2006 | 08:08 PM
ronwc's Avatar
ronwc
I would clean and tighten battery terminals first -
To holy **** another problem
