Boost Lost
Old May 7, 2006 | 12:49 PM
VETTerman1's Avatar
VETTerman1
Default Boost Loss
Will 38lb injectors work with 8lbs of boost? bought the ATI stock P-1SC-1 set up, Then made changes headers; X pipe, 38mm T-body, roller rockers ect... now only getting 4 - 5 lbs of boost... I orderd the 4.60 pully and belt, to bring me back up... I do have a LM1 meter, with HP tuner set up...
Any help Please ! !
Old May 7, 2006 | 01:06 PM
chriswtx's Avatar
chriswtx
its normal to lose some boost when you add headers. with the mods you made, most likely the 38# injectors will be maxed out...I would think they would max out at around 480rwhp or so. Switch to 60#motrons and you wont have to worry about it again.. If you have the 2.0 version of HP it can show you the injector duty cycle...
Old May 7, 2006 | 03:38 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Go with the 60#motrons and be done with it and when you want to turn up the wick further the injectors will be enough for you, I know I run them in my setup and Chris tunes his car and he is right on for the size of injectors to run
To Boost Lost
