HELP ME!!! I have a problem with lg headers
Old May 7, 2006 | 03:48 PM
azamolo's Avatar
azamolo
Default HELP ME!!! I have a problem with lg headers
Hi my name is Alessandro and i am from Italy.
I bought last week the complete off road system from lg motorsport and i began today to install it.
Near the end of the install i saw that there is a problem regarding the spark plgs cables and the headers!!!.
In the passenger side the first and second spark plug cable toch the headers.
I think that if i start my corvette i'll have problems because the cable will burn and maybe the header can arrive to the cable and maybe i'll have problems with my system and missfires.
I would like that you can suggest me a solution to this problem that maybe you havd also in the install of your headers.
Please give me an answer as soon as possible because i need the car because it's the only i have.
I hope that someone write to me the solution to my problem.
Thanks for all and have anice day
Old May 7, 2006 | 03:58 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I have not heard of anyone else having problems with the plug wires and LG headers and that includes myself.
If everything is installed correctly, nothing should be touching the headers. You should be able to use the stock plug wires and not have any issues.
Old May 7, 2006 | 04:34 PM
azamolo's Avatar
azamolo
Hi
Thanks to Mr Z06ufgrad2002
for your answer in fact i never heard nothing about this problem in all the posts i read but now i have this problem and i checked all and all is fine like the nstructions and like the pictures of LS1howto.com
Anyway i am waiting from another person other answers to my problem
Old May 7, 2006 | 04:50 PM
tommybilt's Avatar
tommybilt
One of the boots on the wires on my drivers side rests ever so gently on the manifold. Once I get this thing running I will see how much damage it does.
Old May 7, 2006 | 04:58 PM
24hr Z06's Avatar
24hr Z06
Got a picture? When I installed mine I rotated the boot which got me some extra clearance..
Old May 7, 2006 | 05:08 PM
pinot's Avatar
pinot
Common problem. See link for solution.
http://www.pfyc.com/store/merchant.m...y_Code=VTUNDER
Old May 7, 2006 | 05:35 PM
Patches's Avatar
Patches
The stock boots touched my FLP headers so I bought a set of Taylor 10.4 mm Thundervolt wires and a set of Taylor Fire Sleeves from Thunder Racing. The Taylor wires have a smaller plug boot that clears any header primary easily. I added the sleeves for extra insurance.
Old May 8, 2006 | 02:43 AM
azamolo's Avatar
azamolo
Hi
Thanks for your help, the only problem i have is that i am in Italy and here is not so easy to find accesories for corvette or american cars like is in USA.
I hope that everybody found a solution with the stock cables help me to solve the problem.
Thanks anyway to everybody wrote to me.
Have a nice day
Old May 8, 2006 | 07:31 AM
azamolo's Avatar
azamolo
Old May 8, 2006 | 08:14 AM
vettenuts's Avatar
vettenuts
You may need to go aftermarket, but for now if it is available in Italy I have seen people use the metal lined tubing that is used for heated air intake to the intake, like on a carburated engine. This tubing typically runs between the exhaust manifold and the intake air cleaner. Not sure how to describe it, but it is corrugated and has metal in it. This might get you by until you find a better solution. I would also contact LG directly and explain your situation. He is pretty good about after sale support from what I have seen. Good luck
Old May 8, 2006 | 08:50 AM
kpforce1's Avatar
kpforce1
At least get some fire sleeves or some type of plug wire heat shielding. Headers add a LOT of heat to the engine bay and many people have trouble with plug wires after a header install anyway.
Old May 8, 2006 | 09:37 AM
LETHL_C6's Avatar
LETHL_C6
I got some Magnecore spark plugs with the offset for headers to fix the issue on my car.
Old May 8, 2006 | 01:50 PM
itsmeek's Avatar
itsmeek
i second this..get some fire sleeves for the plug wires- you will be fine.
To HELP ME!!! I have a problem with lg headers
