How difficult is it to replace fuel level sensor?
Old May 9, 2006 | 12:00 PM
gt-hunter's Avatar
gt-hunter
Default How difficult is it to replace fuel level sensor?
Anyone done this yourself?
Any technical write ups on it or should I just take it to the dealer?
Thanks,
Mike
Old May 9, 2006 | 12:59 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
You've got to pull the fuel sending unit out of the tank. It's not too bad of a job, just takes time and can be messy. I've done it several times now, if you've got questions, or interested in going somewhere other than the dealer.
Chris
Old May 9, 2006 | 01:32 PM
gt-hunter's Avatar
gt-hunter
Thanks Chris,
Definitely would be interested in doing it myself if I can...
Any info would be great...
Mike
Old May 9, 2006 | 03:26 PM
Stangkiller
Drain tank, undo the bolts, remove teh floater while pump is still in the tank. slide pump back, and change sender. I think likely you can do this with the pump still in the car. There's one on each side i believe...buti 've only got experience on the drivers side
Chris
Old May 9, 2006 | 11:18 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
pass side is the same, but much easier to remove
the 'contacts' are avail. from GM now seperately
Old May 10, 2006 | 12:55 AM
PierEagle's Avatar
PierEagle
Thanks,
Mike
Are you having the infamous "sudden drop to empty" gauge problem? If so, you might want to try the Chevron Techron gas treatment before you replace the sending unit. If it doesn't work then you could do the down and dirty. Had the same problem about 6 months ago. Used two Techrons and problem disappeared (knock on wood).
Cheers
Old May 24, 2006 | 07:05 PM
hrdse's Avatar
hrdse
Here is a good writeup by ligenfelter on how to replace a stock fuel pump with one of theirs. It covers removing the fuel sending unit and the transmitter.
http://www.lingenfelter.com/pdf/c5fu...structions.pdf
Hope it helps...has pictures too!
To How difficult is it to replace fuel level sensor?
