Rear Diff. Change
Old May 13, 2006 | 09:45 AM
greg 6746's Avatar
greg 6746
Default Rear Diff. Change
I have 98 coupe a4 2.73 diff.Was wanting to change to 3.42 can this be done on jack stands in my garage or do you have to have a lift.
Old May 13, 2006 | 10:17 AM
Mike Mercury's Avatar
Mike Mercury
start here: http://mikemercury.home.att.net/342.htm
Old May 13, 2006 | 11:54 AM
vettezeke's Avatar
vettezeke
Default Yes you can do it on jack stands
I put the front on Rino ramps turned to the front and jack stands under the rear puck points. The top of the fender wells are about 37" front and 41" in the rear. You might not need that much unless you want to get the left cat back out of the way, it takes about that much to remove it.
Old May 13, 2006 | 02:17 PM
almondted's Avatar
almondted
St. Jude Donor '07-'08
Just did mine in my garage a couple of weeks ago. Ramps in the front and stands on the sides. One floor jack and one motorcycle jack for the rear-end drop down. YOU CAN DO IT!
Also here--- http://www.cajundude.com/differential.htm
These instructions helped me alot!
Old Jun 7, 2006 | 01:58 AM
SpinMonster's Avatar
SpinMonster
Originally Posted by Mike Mercury
Mike, I took a look at that sight you made for removing the driveline and all I have to say to you is.....AWESOME!!
It is nice to see that kind of input.
Good job.
Old Jun 7, 2006 | 11:03 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Good job.
I am in the middle of my driveline ripout as well...as time permits
Only a few differences in the 97'
Old Jun 8, 2006 | 12:00 AM
SultansDiamond's Avatar
SultansDiamond
Just curious, why are you going to a higher ratio?
Oops, my bad... just noticed your going from 2.73 to 3.42 - sorry miss-read as 3.73 to 3.42.
That makes sense. I like this ratio too. Not a tire burner, but you'll notice the performance increase especially in the low gears. Good street ratio.
To Rear Diff. Change
